lets see if we can get the triffecta of owners with the name andrew :P
I have only seen it once since Veilside sold it but it looked just as good as before gl with the sale
Thanks Andrew and Leech... we'll see how it goes.
Will be a sad day to see it go (as I'm sure Veilside knows!)
https://www.sau.com.au/forums/topic/136614-car-up-for-sale/#findComment-2540394
I still have the video from when I recorded you driving it out of my driveway and I have no hesitation in saying that I cried.
I've put pics in Andrews for sale thread in the for sale section.
Cheers for the additional pics.
All reasonable offers on this considered too...
https://www.sau.com.au/forums/topic/136614-car-up-for-sale/#findComment-2540825
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
