anyone know of any places that sell nice steering wheels, nothing to expensive, i'm after something a bit smaller then my original one, it just feels to big, also do I need to know anything specific before buying one, I was told i would need a boss kit also my current wheel doesn't have airbags.
thanks
https://www.sau.com.au/forums/topic/136664-buying-a-new-steering-wheel/
firstly, great that your car doesn't have airbags, that means that any aftermarket wheel is ok (if you have airbags yo have to replace with an airbag wheel)
now you do need a boss kit. see all stering wheels have a universal mounting system so basically the boss kit is a small bit of metal that bolts to the skyline steering column on one side and has the universal bolt pattern on the other side. they can be had for about $80 or so at supercheap, or $50 or so on ebay
now for steering wheels... i personally found one on ebay as i loved the design and couldn't find it anywhere else! a decent one can be had for $100 and the quality is great. pics are attached.
you can probably get the boss kit and steering wheel from the same place even!
good luck!
Warren
No, not any aftermarket wheel will do.
Thread starter lives in VIC according to profile.
If it's replaced with something like the one WazR32GTSt posted up, the vehicle will get defected the first time it's pulled over.
That may be legal in some states, but not here.
Some info from VicRoads:
Replacement steering wheels must be not less than 330mm in diameter.
If the original steering wheel was designed with a recessed or padded hub, the replacement wheel must be of similar design.
Something else to also keep in mind. I heard that only momo is an approved steering wheel by insurance companies. So if you are ever in a car accident (touches wood) they could turn around and say, "your steering wheel is not suited to street driving" Don't quote me, but thats what I've been told. Looking for a good one myself :wave:
bull.. There are plenty of other brands sold here which have ADR approval stickers on them, and the insurance company couldn't give two hoots what 'brand' it was. It's like saying 'they only approve HKS intercoolers'
this is a stupid question, how would i know if my car has hicas or not?, when i go to turn the car on the Hicas light comes on for a split second like all the other lights on the dash, apart from that it never comes on
I'd say it does have Hicas. Best way to check is either check via Vin number with fast software. Or get under the back of the car and check if the gear is there.
If you were in Brisbane... ahh... I have a leather momo wheel with boss kit I'm thinking of trading for a nice stock wheel (good condition one). I like the stock one :(
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
    • Correct. Um. I dunno. I haven't cared enough about the way that the NA cars work to know for sure. But..... The 33/34 turbo manual cars have an electronic speed sensor in the gearbox that outputs a +/- (ie, sawtooth AC) voltage signal. That is connected to the speedo. The speedo then outputs a 0-5v square wave (ie, PWM) signal that the ECU (and any other CU on the bus) sees. The speed sensor is NOT directly connected to the ECU. So here's the problem. Your new ECU expects to see the PWM signal, but must somehow be getting a direct signal from the diff speed sensor. Which would suggest that the wiring of the NA car is not the same as the turbo cars. I think you will need to spend some time with (hopefully the wiring diagram for the car) and a multimeter to see what is connected to what. Then, presuming I am correct**, you would then want to separate the ECU speed signal input from the rest of the car's wiring, and probably either buy a speed signal converter, or build one using an arduino (or similar). That would take in the speed sensor signal and output a scaled (and suitably rearranged) signal for the ECU. ** We shouldn't presume that I am correct here, because there might be something else crazy going on. I don't think you could convert the speedo to be fed from the gearbox sensor, because the pulse rate from that sensor is probably different to the diff sensor and then the speedo would read wrongly. And this also wouldn't fix the ECU's problem either, because the ECU doesn't want to see the gearbox signal direct either (assuming that they are all on the same wiring, for some odd NA related reason, see above caveat!) Does this help? Probably not. Can you make it work? Almost certainly. With the above work. You should buy a handheld oscilloscope from Aliexpress so that you can view these signals directly. Connect up the probes and drive the car. Show photos of the screen when drving at known speeds and connected to different places, and we'll see what we can learn about it.
