See ebay item number 280032801839
This is an ECU from a Nissan GTR R32 Nismo edition. (1990) (RB26DETT)
The ECU is a Nissan Genuine Part that has been re-chipped by Veilside. It has their VS Data ROM chip fitted.
Prior to removal from the vehicle it was bench marked on the dyno at 180kw at .6bar and 220kw at 1bar. The engine was stock apart from pod filters. Stoichiometric ratio was in 14.7 range through power run up to 220kw using wide band O2 sensor on 1bar boost.
This ECU was replaced as an APEXI PFC was installed for competition use. It is in perfect working order.
Greg
https://www.sau.com.au/forums/topic/136680-r32-gtr-veilside-chipped-ecu/
Guest
    • The final part arrived today to un-clampify and simplify the intake Who would have though a 1/2" hose stainless bulkhead fitting designed for below waterline bilge pumps would be what I needed Test fit on a 3" offcut I had laying around to see if it would work, and it worked a treat All going well the intake will be on its "final version" tomorrow
