You get a valvebody upgrade from MV Automatics in Adelaide. I had it done. Absolutely awesome.
They do exchange so you buy it and put it in then send yours back for a partial refund. There's an old group buy thread about it with heaps of info.
not if you call a valve body upgrade a "shift kit"
my valve body is original.
just the clutches n synchros inside the box are different.
i will be going back for the manual valve body
and little black box to intercept the auto g/box
computer so i can run a powerFC.
He does the same as MV automatics in that aspect.
I Just started of with strengthen my box before going
manual valve body.
Not sure if its any better then just a valve body upgrade
but it sure is better then stock.
"manual valve body" = stage 3 shift kit
(from what mike at MV automatics has told me)
this means that the gear stick controlls what gear you are in via 1-2-D-o/d and only changes when you change the position of the gearstick
also, RSTME, as far as i was aware, the solenoids which are commonly changed to help with shifts, are part of the valve body, aren't they?
and the most important question is also for RSTME:
do you have any more info on this "black box" which supposedly allows you to run a powerFC? who makes it? what exactly does it do?
thanks
Warren
thanks
Warren
I'm pretty sure that MV Automatics (black box) sell them but not sure if they make em just ring Mike and ask ..........
regards
wrxxy
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
