Hi all
I got this extract from the web:
"To check your booster, with engine off..pump brakes several times to get rid of residual vacuum. Then while holding the brake pedal down, start the engine. If booster is working you will feel the pedal drop. If your pedal is almost going all the way to the floor, it is usually adjustment or air in system. If it is hard and doesn’t move, then it is probably a brake booster issue."
Are the above statements correct?
Lately my brakes seem to have deteriorated. There is more pedal travel in the brakes, especially after driving it around for a bit.
When stopped at the lights and hold the car still, I can push the brake pedal further by stepping on it really hard. It feels as if it might hit the bottom but doesnt quite get there.
When I tried the above test with the car off, I pumped the brakes until they became hard, then started the engine. The pedal dropped down a fair bit, but again, didnt hit the bottom.
Also, when I am stopped at the lights, I have tried pumping the pedal several times. It doesnt get harder or softer, and the pedal doesnt come up from its original position.
I am a little worried because every now and then when I brake, and brake hard, it feels like the brakes dont wanna stop the car.
I have machined all 4 discs, replaced all 4 pads with good ones, and have driven the car over 5000kms since. I have also had a mechanic bleed the brakes twice with good fluid. There are no signs of leaks as I have never had to top up my brake fluid in the year that I have had my car, I also cant find any leaks anywhere.
Any ideas?
Thanks, much appreciated!
https://www.sau.com.au/forums/topic/136710-issue-with-brakes-can-anybody-help/
I think a master cyl rebuild might be a good idea... But ask your mechanic. I dont think the brake booster stopper is the logical next move. Make sure everything is working as it should first.
    • This sounds like someone who would have owned an R33 in their past... It's okay, I'm 100% picking up what you're putting down Mark.
    • Just back on what was raised about jacking off the the tow/tie down point on the front of cars. I've used it plenty. I've also watched it on a car where you could see it move the front end of the car. It was like the front end/whole car being tweaked and twisted a bit. I will say, I struggle to find good jacking points on MOST cars. The ones that have good points, I then normally struggle to find a jack tall enough to make the car change height!   One of my go to points for either the jack, or the axel stands though, is either a suspension pickup point, OR a subframe to chassis major bolting point. I actually think its the subframe on my R33 that has a bit of a bend in it, from being jacked in the middle too. However, it could have been one of my many other cars I've had over the years! Or it could also be the from me jacking it up, and the fact the top of the front radiator support isn't there, so it can allow the front of the car to move and bend etc.
    • My apologies. I forgot we were talking about weird beard M series stuff. Had been talking elsewhere with someone about an R33 with similar subject and got confused.
    • Nope, I don't like the look of ND RF, or any ND really, I don't like their faces or arses, why, because of their "modern" lines, the NC, whilst "modernish" has a more rounded shape that I like Well, that's how my overly judgemental eyes see it anyway
    • Should be more than fine, especially the overall fuel pressure would never exceed 3.5bar (assuming that thing never gets more than 0.5bar of boost in stock form). According to the chart, it's 11amps.
