Just saw this in the Trad Post (no its not my car). Is there that much difference between the original 100 Nissan Australia cars and the imports ?
NISSAN SKYLINE GTR 1991/1992, Australian Compliance, 1 of 100, 99800kms, burgundy, log books, VCW-065, $29500 or near offer EARLWOOD 0411-49 9799
This seems cheap, although the Kms are higher than some imports for similar money ?
https://www.sau.com.au/forums/topic/13682-aus-spec-or-import-gtr/
I believe there wasn't much difference, the Aussie GTR got an oil cooler for the transfer case, and maybe an engine oil cooler but I'm not completely sure.
The Aussie delivered normally fetch a lot more than the imports. 2 weeks ago I saw a black R32 GTR at Peter Davey Toyota for $44950!!
MX8: another reason Aussie spec cars are often alot dearer is the history that comes with a locally sold vehicle. Most of the time you can get service history with aussie spec GTR's which is real peace of mind when you buying a hi performance car.
Also there *may* be a slight cost saving on insurances being locally delivered.
The extra cost usually associated with Aust delivered cars comes from them having service history etc too prove the amount of kms they have done. These KMS in this car are probably genuine where as you could add anything upto 100,000kms onto what an import says on the clock. I should know I looked at heaps and have bought one. Many of the imports said 70,000 kms on the clock. Yeah right. Lucky if they were 175000.
That is a cheap car for Aust delivery and if you are looking may be worth a look. Be careful though. A lot of people get into the 32 just being able to afford then and then something goes wrong and the extra $5-10K they cannot find.
Mick.
The aerials on Oz Spec models are different to the imports as well. Australian delivered 32 GTR's have small external aerials mounted on the roof at the middle point apex of the front windscreen. Imported versions have built-in aerials. The only noticeable trait of these is when ur sitting in the car you can see a thin strip of line running vertically on the passenger side of the front windscreen.
My 32 has the roof mounted aerial also!! I dont know why its on there because the windsreen has the actual antenna in it. I think Mark Skaife has the number 1 of 100! Still having any aussie deliv GTR will up the price.
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
