  • Replies 89
Posted Images
Its andrew hey all
listen to this new song only if you like hip hop the second one is the best fully sik :laugh:
http://au.wrs.yahoo.com/_ylt=A9FJqiRMkSNFz...ossy%3ffrom=rss
http://au.wrs.yahoo.com/_ylt=A9FJqhmYkSNFW...dsup%3ffrom=rss
copy and past sorry
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
