For Sale
5 puck, brass button, sprung center clutch
to suit R33 GTSt (or similar/compatible design)
hardly used, can be said this thing is new (driven less than 20km)
was put in, tested then taken out out about after about an hour
asking $220
PM me for details/info/number to contact
https://www.sau.com.au/forums/topic/13683-fs-heavy-duty-clutch-pressure-plate/
was too rough, had troubles changing gears
daiken had stuffed something up when they were working on my clutch
we put this pressure plate in and for some reason didnt suit nor liked the way it was working
its in working order, just didnt suit my application
what was your 'application' im a daily driver / will be going to calder sometimes and booting my car a little here and there (providing there's no ****ing cop SSs around), sorry private joke :S
so i guess this one is too hard for my use ?
i wouldnt say so
its about the same clamping pressure as the daiken organic h/d clutch (thats what i got in instead of this)
not sure why, but for some reason it wasnt making a flush press/connection
dont ask me, i cant get technical...but i can ask
thing with a brass button, its alittle "b|tchy" when it comes to traffic/parking as u either have it ON or OFF (five puck)
L3ThAL - i had the same clutch in my series 2 (and i think the same in the GTR) - they're very nice, either on/off, but they suck in traffic.. it gets a little tiring because its hard to ride the clutch etc... the car jumps a bit sometimes and makes noises etc... they are a rought clutch, but very very good.
sorry to step in, just thought it may help
thanx PranK, but yeah...its a b|tch to drive, but u get the hang of it in time
need to change your driving style
G0DF4Th3R, sorry dude, its just the pressure plate :( but thats all that i replaced in mine, and daiken did some other "stregthening" stuff, something to do with springs and pivot points *shrugs*
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
