I've not had the GTR experience but if the AFRs and timimng are right it should not be shoking if driven in normal mode .
I got some pics somewhere of a couple of engines being tuned on Allen Engineerings engine dyno using Autronic map sensed computers . It seems they like to have a MAF sensor in front of the turbo and log the airflow input as they tune . Message in there somewhere .
as jon said hyperdrive here in wa who are one of the biggest workshops push the djetro for larger twin turbo gtrs to eliminate turbo shuffling
fit and tune is about 100$ more that std pfc .
given the djetro is about 300$ more than std and 100$ more to fit and tune I think your still up on the cost of x2 z32 AFMs bought new plus all the changes to the intake to fit them
Edited by arkon
Just to clarify, the first tuner I went to had a lot of dramas and I ended up taking it to Mark Jacobsen at Godzilla Motorsport and he had no problems at all. At the time I would say I was one of the first D-Jetros in Brisbane but I would say by now there are quite a few people who can tune them.
And as for fuel economy, I've never referred to any GTR as having excellent fuel economy with any ECU. :no:
Hey,
main post updated >_< I'm not hugely worried about the tuning side of things; more about the running. Yes, the running's only
as good as the tune; but if I can run a D-Jetro and have as good running behaviour from the D-Jetro I'd like to delete the AFMs.
Thanks again,
Saliya
edit: anybody from Sydney running a D-Jetro that would be willing to chauffeur me on a short trip? Anyone ? :happy:
A case of New could be yours for the having if bribery's required :spam::huh:
Edited by saliya
So - anyone else with a d-jetro? If you don't want your information publicized I'm happy to add it to the initial post anonymously.
Anyone want to 'dob in a mate' (I will PM them privately) :laugh: :laugh:
Thanks,
Saliya
I've just had a d-jetro fitted to my R32 GTR>
-Driveability is perfect - makes 247rwkw with stocker turbs on 1Bar
-Fitted and Tuned by Hyperdrive in Perth
- Not sure how long it took exactly- left it with them one day picked it up the next
- standard plenum/throttles
Not sure what all the negative press about d-jetros is all about?
If you can pick one up for the right price like I did, then why not.
Cheers,
Tay
p.s. And if it's the price you are concerned about - sell stock afm's and there is the small difference ($400 odd) referrred to earlier.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
