  • Replies 56
i got my first birdie there, sad thing was it was only a few years ago. for the people going i would take extra golf balls or buy extra balls there. even thought the longest whole is only about 80m or so, if you slice it off the fairway the ball will be lost forever. also if you are still up for some more action after go to the baseball machine at golf paradise next door.
im in.
this looks like a good turnout. we're going to have to book in advance Dino and we'll end up with a few groups. made a list cause i was bored, hope you don't mind Dino. if you do :shake:
List so far
red900ss - Dino
PeakRPM - Andrew
B-Man - Brendan
Blitz - Nick
URMINE - Paul
Majanal - Dan
benm - Ben
Ronin - Tosh ?
akira - Akira
Doctor - Ben
two40 - George
Carlo - Carlo
DLuded - name
if anyone else is interested, please copy the list and add your name at the end
Monday 21/4/03 at 2 pm.
nb. This place is next door to Golfer's Paradise.
See you all there. Please post if you are not coming, and anyone else please post if you are. :P
http://www.par3golf.com.au/
and like Dluded said bring lots of spare balls. If you connect with any they'll go sailing off into the bush. smilie_golf.gif
Originally posted by benm
Pffft QLD... nothing but inshape blonde tanned women 1/2 naked on the beach, why would u wanna go to QLD for the long weekend ?  :D
When benm would quite happily hook you up with a few of his fine skanky mistress's
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
