Hey all, got out of work today and what do i find my door handle jammed up(the whole thing) and my lock destroyed. Thank god the little bastards didn't even get into the car but it is going to be a pain in the arse to replace/fix. If i came accross them i swear i would rip off there nuts and make them watch me grind them into mince meat.
Now i have that off my chest is there any place in adelaide that would be a start to look for new one? price?post-15951-1159963160.jpg
https://www.sau.com.au/forums/topic/137328-attempted-break-in/
Sorry to hear about it! You'd be surprised what a crash repairer could do with that .... I had my S15 fixed (had 50% the damage of yours) including respray door for $350. I would ask at Nissan dealers for the actual door handle and lock - should be easy to get (mine was fixable). Expect about $200 for handle and lock I would think.
Thanx guys, i will go see one of my dad's friends tomorrow before work see what he thinks at least you have given me a little hope that it might not be too bad. i'm also going to see if there is video on the carpark. i did find it funny that they hurt themselves in the process and left disgusting blood on my car.
^^^ I'm hearing ya, they touch ma car and i'll touch them! Also another reason to have a daily....... while my line is locked up under a car cover! working arvo shift in Plympton isn't the best place to be driving my car, espesially when i went out for 5 mins a few months back and noticed when i came back there was a car on fire down the end of the road!
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
