i bought a set of r32 front breaks for my car, the breaks are in good condition but it has some surface rust on the rotor nothing major, its just from not being in use, what i want to know is how do i get it back to its orig. shinny look, do i use a very light sand paper and lightly sand it or should the break pads take care of it for regular driving?
any help would be good
thanks
https://www.sau.com.au/forums/topic/137365-r32-breaks/
thanks
yeh, u can just take off the surface rust using some very light sandpaper but try keep a co-centric motion towards around the rotor, but try not to leave any deep scratches. other option is to just take them to a brake place and get them 'skimmed' - not machined, just a lighter version to take the rust off. or u could just run em with ur pads, but that rust is just going to clog up the valley in the pad and most likely create build-up, so thats not really ideal.
https://www.sau.com.au/forums/topic/137365-r32-breaks/#findComment-2555925
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
