Hey all,
I am looking at buying a set of rims/tyres but i can only get them from NSW and i live in Brissie so i was wondering if they would fit on my car before i purchased them and just hoped. The dimensions are:
18X8.5 +35 offset
With 245/40/18 tyres most likely, maybe 255's on the back
They are to go on an r32 gtst with widebody front guards
Cheers
Ryan
The car is lowered approximately 1.5-2 inches if that matters.
They are only for the street so they wont need huge clearances for body roll etc. as i have a set of 16inch rims for the track
https://www.sau.com.au/forums/topic/137423-will-my-wheels-fit/
hey mate,
glad you read my thread..
mine fit fine with no problems at all.. ie no modifications needed
personally i think you'l be laughing
the guy i bouight the wheels off had them on an s14 200sx with the car lowered very low.. he had no problems with fitting
and he had the stock guards too...
hope that helps!
They will probably fit but i think you'll need narrow tyres on the front or you'll have clearance problems on the inside.
Take a look at this thread for some pics of clearance issues with 17x8 +35 rims and 235/45 RE540s.
8.5 +35s should have 6mm less clearance so you'll have less room to play with than me. Narrow tyres should get you a bit more room.
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
