Im experiencing some knocking noises from the rear of my car and i have been told it may be the pillow balls are worn on one or both of my rear coilovers.
I have Racing Gear JTC N1 coilovers which which are pretty rare and came from Japan.
I am just wondering if it would even be possible for me to replace the pillow balls. Where would i find some?
start by trying the suspension places - they'll point you in the right direction.
you will be able to replace them but they're probably not cheap.
i think you can get HKS pillow ball mounts from nengun or greenline by memory alos...
The knocking isnt anything bad
My coilovers have done it virtually since i got the car 2.5 years ago.
Its just because they wont have rubber on em like the factory ones.
No biggie unless you dont like sounds
it usually is. I dont know what nismoid is on about, but they shouldn't knock, or squeak at all when everything is as it should be. not "having rubber on them" (where do you mean?) wont make them knock. I would look at getting them replaced if the rose joint is sloppy.
Maybe more poor information from another crap workshop here in melb :)
Centreline told me that it was ok if they were a bit noisy and wasnt of great concern...
But then they told me other things aswell that ive found out were a little "inaccurate" :D
yeah, they were probably just a tad lazy. i've had pillow ball upper mounts both without a piece of rubber between the upper srping seat and spring and with the rubber (I assume this is the bit you meant) and neither made knocking noises. I have on the other hand had coil overs that knocked and sure enough, removed the upper mount and the bearing was sloppy. got it repalced, noise went away. sometimes when the dampers are shot you get a very similar knocking noise too.
a dude here in sydney did it for me. He basically took it to a couple of bearing suppliers until one would take the time to find a match. then had the old one pressed out, and new one pressed in. the bearings are usualy in a steel housing which is then bolted to the alloy outer piece.
    • Was the failed sensor by any chance this one? Did it just fail or start pissing on itself? I ordered one too, for fuel pressure monitoring, and now I am hesitant to put it in, hehe. Where did you find a brand one?
    • You'd be insane, when a brand new 8HP is ~$4k, and all the work to put a 6 in would cost the same as an 8 and the 8 is a completely established swap. If you think that getting a cheap Falcon box is going to make it a cost effective exercise, then you're not accounting for the extra $10-15k that the task will consume.
    • any further information on this? also interested in putting a zf6 in behind a rb30!
    • They're all horrible. X-Trails have had a nasty sounding 4cyl since forever, no matter what engine family it came from. The CVTs only made that worse. Then the whole Renault thing only made every Nissan that was contaminated by them even worse again. The only fun I've had in a X-Trail was having it blown sideways across a frozen Minnesota highway at 90 mph trying to make it to the airport to get out of the frozen hellhole of Hoth. Nearly died. Was great fun.
    • Alrighty, I'll have to grab a couple pics and type out something soon in another post. I haven't driven a modern X no, this would be the first one really. Yeah the rental boxes are always cheap as chips right? So I'd doubt that anyone was handing out GTs to go and abuse. But I s'pose I could be wrong for sure. New cars these days though? Pretty unimpressed with what I see now; 20 years and all that, like you said. It just kind of worked out to have these two cars now. I'm pretty pleased with that, don't need much else. I'm sure you lads are right about the temps and for sure, you wouldn't have much time to drive 'em down there if you all were like me. I do hate sweating all over the seats though😆
