Anyone has got the Auto Gauge smoke face boost gauge? It comes with a "T" piece with build in restrictor and just wondering what does it do to the boost reading. Due to the larger "T" piece supplied by Auto Gauge, I did not use the "T" piece. Instead, I just use the old "T" piece from my privious gauge and now boost reads 1 PSI lower! Which reading should I trust? Anyone can help?
https://www.sau.com.au/forums/topic/137759-auto-gauge-smoke-face-boost-gauge/
is this the t piece that you use to tap into the vacuum line in the engine bay?
as far as i know, that line doesnt need to be restricted, u just want to carry the pressure to the gauge.
if you just use a t piece thats suitable to the diam of the hose, there shouldnt be any issues.
inaccuracies might be due to it being an AutoGauge.
Hmm interesting. I never thought about that. I think I reused a diff t piece and mine reads 1-2 psi too low.
in my experience with cheap ass gauges. they work ok for a little while, but after a few months you would get a more accurate reading by sticking your finger in the turbo inlet and measuring how much it hurts, then derive your boost reading from that.
lol, well the 12 year old in china who assembled it must have had a particularly good day! :(
but you did say it's not accurate? but i guess consistently inaccurate is kind of better than varyingly inaccurate.
Same gauge here..
Compared against a mechanical gauge it was over 5 psi out (low).
Currently resides in the round filing cabinet.
Looking for a decent replacement.. Probably get a greddy mechanical as it will go with my exh temp and oil temp electrical gauges, unless anyone can suggest better / cheaper (not exclusive).
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
