As per the topic, I'm needing a new battery as I've had a few problems with the one that's in there now. So I was wondering instead of just wandering out and buying whatever fits, do any oy you R33 owners have anything you can reccomend to me as a decent battery, cause I've had enough of the crappy thing that's in there atm. Cheers :thumbsup:
https://www.sau.com.au/forums/topic/137876-battery-for-an-r33/
just a quick pointer....you sure its not your altinator? coz i thought i had a bad battery in my old car and i replaced it only to have the new battery to die. I hope it is your battery coz they are f**king expensive.
Hmm... The car started after work. Made the sound that trying to start on a near dead battery (that kind of high pitched whirry noise) then turned over. I tried it another couple of times since i was all "WTF?" and it started no problems. Anyone have any idea what this could be? Alternator? Mechanically, I know bugger all. There have been another couple of instances in the past where the car didn't turn over properly (but not like it was a flat, just made that whirring noise then started on the next try) so now I'm fearing the worst :)
The dry cell ones are awesome, however for the price i wouldnt bother.
I just got a run of the mill one from autobarn, there's one that suits the R33, its in the booklet thingo there...
yuup did the same, working a treat, although dont have any heffty strains (woofers) on it, so it depends on what the battery will be driving in the long run :)
If it is just the battery theres a wholesale place over in Queanbeyan (on Uriara) he just searches up on his database whats available for the make, model and year, walks into his factory and comes back with the battery for about 30% cheaper then youd be expecting at battery world
Check that the alternator is charging and also put a booster pack on and see if it still does it as it could be a starter or ring gear problem. If it is a battery then all i can suggest is you buy the one that has the most CCA which is cold crank amps, as i looked into the oddysey batterys and i found that they had lees CCA than some of the others. AGM or dry cell are excellant but pricey.
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
