80's style television channel names, thats what it means
ATV9, GTV10, HSV7
Check out some of the classic old tv guides
http://televisionau.siv.net.au/tvguide.htm
September 1989
http://televisionau.siv.net.au/tv250989.htm
you can't do that on television
double dare
hunter (the dude with the stupid cat)
happy days
Notice how many movies were on back then
:sorcerer:
https://www.sau.com.au/forums/topic/137953-atv-gtv-hsv/
They are the names of the actual stations themselves. ATV 10, HSV 7, GTV 9. All of those stations are in Victoria thats why they end in V.
But in NSW the stations in Sydney are: TCN 9, TEN 10, ATN 7. They all ends in N because they are in New South Wales.
In QLD they are QTQ 9, BTQ 7, TVQ 10, and they are all in QLD.
Get the pattern!!
The reason why they were refered to as these names is because each station used to run as its own entity also showing slightly different programming in each state. Now with the digital television telchnology they all run nationally out of one office, for example channel 7 national runs out of the melbourne office HSV. Channel 9 and TEN run out of the Sydney office (TCN & TEN). So the stations have now cut down there over heads by centralising their broadcasts to one city. Internally they still refer to them as the original names.
You asked I answered!! probably not that relevent though, cool programming guides too!!
https://www.sau.com.au/forums/topic/137953-atv-gtv-hsv/#findComment-2568831
Man theres some classics, F2A TV really does suck these days!!
CH9. 3.50am Movie: Bikini Paradise. 1967 This sounds good, bet this was probably one of the last times ch.9 put on something decent besides news, aca programs and just rubbish in general :D
Anyone watch Full Frontal and Fast Forward on FOX?(Got it on right now), thats something they need to bring back for primetime tv!
https://www.sau.com.au/forums/topic/137953-atv-gtv-hsv/#findComment-2568956
Get the pattern!!
Thanks miss I worked at channel 7 for however long... Miss inside information! hehe :)
https://www.sau.com.au/forums/topic/137953-atv-gtv-hsv/#findComment-2570927
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
    • With ordering the belt, you're doing water pump and the idler and tensioner at the same time too yes?
    • This is just a dumb way of keeping the wastegate closed to make more boost. Undo it and either follow the factory setup or redo it properly. Manual boost controllers just use a spring preload to determine when to close in response to boost pressure so it no longer vents to atmosphere.
