after years of pondering and looking i have finally found how to do it the Jap way. have a look at www.takakaira.com. they're selling a system which reroutes the fuel dump to the exhaust when u hit the rev limiter, thus making big flames come out.
i used to think the flames were from anti-lag system(in wrc cars), but i think those flames are not as big as these. and guess what car they use for the demo? GT-R 32!!
https://www.sau.com.au/forums/topic/13800-flames-outta-the-exhaust/
My GTR blows huges flames out the exhaust on some gear changes & does not have anything fitted to make it do it, maybe it's just the tuning.The R33 does it on the start line every time, & on gear changes.It is usually just a qick flash not a continuous blast.Does look good at night thoughon the track.
Hi Guys, we run excessive fuel on the overun to cool the cylinder heads, it's an old trick. This unburnt fuel ignites due the heat of the pipe and/or when you get back on the throttle. It knocks about 5 to 8 degrees off the head temperature.
Hope that adds to the knowledge base
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
