After much contemplation ive decided to give up on the rb30det as ive become a first year aprentice and the pay ****ing sucks major ass and ill never get it finished at this rate so ive decided to sell it to some one who will
I originally brought the head and that was it i havent done a thing to any thing so its still a original head.
It comes with rb25 head, cams, covers, coil packs, injecotrs, fuel rail, standard plenum, standard exaughst manifold, loom all the standard **** on the head.
also chucking in a rb30e bottomn end that i started to rebuild but never got any further then stripping it has all the components off it like water, oil pump, crank, craddle, tensioner, rods and what not,
Ive also got ristrictors for the head which ive not put in yet some where which i turned up myself 1.5mm hole
after 850 for the lot
Ill take some pics tommorow
Cheers
Kris
https://www.sau.com.au/forums/topic/138131-rb25-head-unfished-project/
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
