This is how it goes.. When you say tacho you mean engine revs yes? then you mention speed.
Engine Revs is correct on the power FC compared to the stock tacho meter
SPEEDO can be correct on the indash display and not on the PFC or vice versa OR they could be both wrong.
Get someone in a late model car do some tests with you on speed one check at 40 then 60 then 80 then 100 etc etc
Then you will know which one is correct.
My PFC speedo used to be correct then i got a different ratio diff and now the indash speedo is correct.
https://www.sau.com.au/forums/topic/138200-pfc-hc-vs-tacho/#findComment-2573605
Yah, I agree with Troy, engine revs would comes from same source, and feed both FC and dash gauge.
The dash speedo though would be from a cable connected to gear box. As evident when heavy breaking and accelerating, there can be huge hysteresis in the needle.
PFC would however take the speed from the hall effect sensors on each wheel for your ABS system. Me think the requirement for the ABS to have a good idea of vehicle speed, would automatically mean its more accurate then the dash speedo.
2c
- Michael
https://www.sau.com.au/forums/topic/138200-pfc-hc-vs-tacho/#findComment-2574961
I think speedos are all calibrated to overread by a small amount eg 2%. All cars do it.
I would trust the PowerFC especially with the RPM - after all, its the PowerFC that should know it better than a dumb analogue needle because it controls the darn motor!
https://www.sau.com.au/forums/topic/138200-pfc-hc-vs-tacho/#findComment-2581544
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
