  • 3 years later...
Hi, I have some scratches in my windscreen from a windscreen wiper which broke - the metal on the windscreen wiper arm scratched my windscreen. I would prefer to fix this at home. Do I use normal paint polish or can you buy glass polish?
I usually use a Driven extreme duty glass cleaner to remove heavy water spots and some light scratches caused by grit that have been stuck on wiper blades.
http://www.reflecteffect.com.au/products.p...s&prodId=c1
I do this with a rotary and a cutting foam pad as it would be abit of work doing it by hand. It does leave some micro scratches so you will need to follow it up with a meduim abrasive polish.
easy job you will need cerium oxide if they are light Scratches, if they can be felt with a fingernail they will need to be ground out with a stone first < i would not do this if you have never done it :)
you will want
some cerium oxide powder for the polishing
a polishing pad (suggest lambs wool, felt or leather) mounted on a backing disc
low speed drill (1500 rpm or less) to use with the polishing pad - polishing too fast will generate excessive heat and may crack the glass. :/
a marking crayon to mark the inside of the glass (use this to guide you when polishing)a cleaning cloth to wipe and allow inspection of the work area
small spray bottle - use to apply mixture to glass and keep moist while polishing
how to do it
  1. Mix some polish into water to a form a thin slurry (eg. milk-like consistency) - we suggest mixing in a small spray bottle which can be used to apply to polishing pad
  2. Clean glass thoroughly to remove all traces of dirt and grease
  3. Apply polish mixture to the polishing pad
  4. Mark the inside of the glass with the crayon to identify the area to be worked
  5. Mount pad in the drill and apply to work area.
  6. Move pad up and down, left and right in work area.
  7. Keep the surface wet to prevent glass getting hot - if sufficient polish has already been applied, then just spray a fine mist of water to keep the area cool.
  8. Wipe off residue and inspect repair - keep working until polish is satisfactory
  9. Wash and store pad for later use
Edited by cthawes
    • Possibly avoid using a Cometic one unless the deck/head surface are perfectly flat. I did have a look just then and forgiving gaskets such as Tomei or Nitto don't exist for the FJ20, however the Bar-Tek or Kameari ones look good and might do the trick.
    • Because pipe threads for pipe things. M threads for bolt things. Throw some teflon sealant onto it and dust your hands off knowing you did the right thing, instead of going twice around the block to achieve a result using the wrong things. Of course, all of these solutions are ignoring the fact that the minimum thread pitch we're talking about here is 1.25mm, with the 1/4" in NPT or BPS being out around 1.4mm. You will need to know that the boss you're tapping has enough thickness for at least a few threads. That's one of the reasons that 1/8" is commonly used - because the pitch is <1mm. And why would you look to use 1/4" NPT in a BSP country anyway? Ugh.
    • Just throwing around ideas, does it need to be in the compressor cover? Why not the hot side piping?
    • 1/8NPT drill size = 8.7mm. Since the hole got messed up by me, it’s probably around 9mm.    So 1/4” NPT would be next step. A drill size of around 11mm would be preferred there which is not way of my M12 (drill 10.5mm and tap M12 threads)
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
