Hi Guys,
I've had some issues with my 32 gtr. Mods include: GT 2860R Turbos, Cooler, Splitfire coils, PFC. Currently making 275 @ all four.
I've had some severe missing issues with the car lately. It got to the point where the car was running constantly on 5 cylinders, even on idle. I was getting knock levels up at around 105!
I took it to my mechanic and he changed spark plugs, tested coils, changed ignition amp, cleaned AFMs, replaced the wiring harness, comp tested motor. Car was running fine for about 30mins before it started again.
I put in my old ECU, took the car for a drive and after about 30 mins it started doing it again. I put the ECU into diagnostic mode and error 45 came up - injector leak.
So what exactly does an injector leak mean?? Do i need new injectors?? Could it be fuel pump??
Any help would be appreciated. ;)
Cheers
https://www.sau.com.au/forums/topic/138638-ecu-code-45-injector-leak/
Its means the injector is leaking... Probly one of the o-rings is split.
Im not sure how it would recognise this fault, maybe a big vary in one of the inj duty cycle?
The knock sensors can pick up noise from the missfire and log that it was detonation, And In your case it sounds like the spark plugs/plugs are foulded.
Pull the injectors out replace the o-rings in all injectors, even while their out get them flow tested/cleaned make sure theirs nothing wong inside the injector - I wouldnt think this is common.
Also if it was that bad, change the oil... fuel in the sump = spinning bearings!
See how you go!
No such thing as error code 45 according to the R32 GTR factory WS manual, you'd better re-check. In any event the stock ECU diagnostics aren't set up to detect injector leaks as already suggested.
Edited by SteveL
id be surprised if the ecu could detect injector leak also, it would have no way of knowing. read the powerfc faq in my sig, theres a known misfire bug in the r32 gtr powerfc and it outlines a working fix for it
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
