post-32230-1160823598.jpgG'day guys, i recently bought an r34 gtt and would like to put the boost up. the only mods i have are exhaust, intercooler, and now a boost controller. as far as i know its ok to have 14psi on stock? do you think thats ok or will i fry things like the turbo? what is a good boost to run on the neo 6??
https://www.sau.com.au/forums/topic/138693-upping-the-boost-on-r34-gtt/
most people say 10-12psi. it really depends on when the ecu hits rich and retard. you will know when you hit this as it kills the motors power. it retards the timing and richens the fuel right up.
i run 14psi on my 33 with a remapped ecu. goes a lot better than 12psi, and when my turbo blows i have an excuse to get a new one.
so i could run the standard boost on low and maybe 11psi on high you think and that should keep me happy and stop me from spending more money. after buying the car i dont have much of that left! she's only done 35000 k's!
I found 34 gtt's hit r&r a lot easier and harder than r33's. I dynod one stock, and then after a turbo back and front mount, nothing else, and r&r was savage, lost up to 30 kw, only gained about 5kw after it clawed its way out of the hole.
well maybe you coulod get a fuel cut defender, or if in your budget just get a pfc now save your hassles later on, just a thought if not try 9-10psi if it retards then just back the boost down, it will still feel better than standard.
Have a look in the trader section search a user by the name of performance-wise he does group buys on powerfc's with the handcontroll for under 1000 delivered i just bought a unit through him very good to deal with.
They are a complete engine management computer which replaces the standard ecu allowing the car to be very efficiently tuned getting the most out of the engine and its modifications.
Edited by fEkuaR
thanx man, just checked it out, should i still be buying my electronic boost control or does the power fc cover that as well?
You can use a apexi boost control kit that goes with the powerfc. Or you can just run a seperate boost controll unit. The boost controll kit with the powerfc is a little extra but if you havnt bought a controller yet id go with that and get it at the same time you can buy it with the group buy aswell.
When your turbo blows the smaller ceramic particles that can result can find thier way back into the engine. This is why blowing the stock turbo isn't a good 'plan' even if it's the excuse you want to buy a new bigger one.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
