Man I'm stupid, finally figured it out. All the pics I keep seeing of the 350gt-8 are the 2001/2002 models. Mine is a 2003 and has had a few changes. I found this on the nissan global site:
Skyline Sedan Undergoes Minor Model Change
Among the refinements made to the Skyline Sedan this time, the 2WD models now have higher spring rates, shock absorbers with approximately 30% greater damping force and larger-diameter stabilizer bars for better control of body motions, compared with the previous models, and thereby deliver a tauter driving feel. In addition, braking performance has been enhanced by adopting a braking system incorporating high-performance sport brake pads with an increased friction coefficient and highly rigid brake rotors with an outstanding heat radiation characteristic.
The exterior design projects a sharper impression than before as a result of applying a smoky chrome finish to the grille and headlamp inner panels and changing the sill color from gray to black. At the rear, the car badge and Skyline emblem have been repositioned to give the rear-end a wider look.
On the inside, the audio and heater control switches have been embellished with a chrome accent for a higher quality image, and the 250GT and 250GT FOUR models are provided with rear-seat air-conditioner vents for enhanced occupant comfort.
The grade selection has also been reorganized as part of this minor model change.
<Major specification and equipment refinements>
Exterior
Repositioning of the rear car badge and Skyline emblem
Refinement of the design of the radiator grille, headlamp inner panels and sills
Addition of Sparkling Silver Metallic and Rose Red Pearl as new body colors for a choice of six attractive colors altogether
Interior
Refinement of the control switch design
Adoption of sun visor extensions
Addition of a light to the front-seat vanity mirrors
Adoption of a double-pivot rear-view mirror
Expanded application of rear-seat air-conditioner vents to the 250GT and 250GT FOUR models
Mechanisms
Refinement of the suspension and braking system
https://www.sau.com.au/forums/topic/139059-wtf-is-this/#findComment-2591299
yeah i saw one of these on the road a while ago, and it threw me. didnt know it was a skyline till i saw the badge. looks more like the new maxima or something.
what engines do these have? turbo? i know i could google it, but meh.
https://www.sau.com.au/forums/topic/139059-wtf-is-this/#findComment-2604721
  Munkyb0y said:
ok, i cracked and googled, lol.
3.5L DOHC V6 NA. meh. i dont really like it. very family/maxima. how can they call this a skyline????
VQ35DE (NEO) type V 6 cylinder DOHC with an X toroid CVT 8 speed transmission.
It's more than worthy of the skyline name and is totally different to a maxima.
I parked mine next to a maxima the other day and they look totally different.
https://www.sau.com.au/forums/topic/139059-wtf-is-this/#findComment-2606849
id get the coupe - but its similar to the 350z i reckon.....bah just slap on a turbo when modding it - works well either way....
Edit - ok maybe interior is not that much like the 350z - i dunno...gives me the impression that one of them was trying to copy the other....
Edited by emsta2003
https://www.sau.com.au/forums/topic/139059-wtf-is-this/#findComment-2606996
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 馃憣). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
