Hi there,
Ok I currently have an R33 gts-t ser 2 with the following mod's:
-Boost set to 11/12 psi
-CAI with Pod filter
-Full 3" exhaust (one piece front dump from turbo, hi flow cat and the trust cat back exhaust)
-Oil/air seperator
-Font mount I/C (Apexi Hybrid)
-17" 235x45 front and 17"255x40 rear
Should be about 180/190 rwkw's.
I guess my aim is about a 13.5 second run 0-400 meters. I am not looking at changing injectors or internals of the RB25det.
To me the car feels average (because I'm so used to it...).
I would like some advice from those out there that were in the same situation or know about this.
Should I go down the path of getting the turbo high flowed and replace the shafts with steel units?
And if I did this will an SAFC work well?? (don't really want an power FC)
Keep in mind I don't really want to totally change turbo's or waste too much money.. The most I want to spend from here is about $2K ($500 for SAFC and $1500 for hi flowed turbo).
Can anyone also tell me what sort of rwkw's I could get from the above? And will this help me net a sub 13.5 second QTR mile run?
Thanks for your help
Rob
https://www.sau.com.au/forums/topic/13914-goal-of-135-sec-0-400m-advice/
Forget launching at 3,500rpm.
If I launch @ 2,000rpm my car just wheelspins and then drives off, If I launch at 2,500rpm with a full car load - (200+ kg's extra over the back wheels) it sits and spins even more.
I find giving it about 1,500-1,700rpm works best for me (but then again my tyres are sh1t).
Go grab yourself a fuel regulator and an exhaust cam gear and give it some more tuning and you'll crack the 13's.
Thanks for all your reply's.
Just wanted to clarify a few things,
1) Some of you say it is possible to crack a 13.5 (taking into consideration driver skill), Is this with a high flowed turbo and SAFC or with what I currently have?? (should I just get an SAFC and leave turbo?)
2) Has anyone actually high flowed their turbo (and replaced shafts with steel unit's)? How successful was it?
At some stage I will go to Eastern Creek for a run (never done it before... should be fun).
Thanks
Rob
I've got a consistant 13.5sec car and I didn't have a hiflow or a S-afc to get there.
I'd forget about the guessing and go hit the track. You will need some experience to make the most of any mod when it counts 1/4 or otherwise. Besides you go down to the track to have fun, not to show off your times (you do that when you go home and post it on the forum :) ).
Once again thanks for the replies.
this may be a frequent quetion, but what is involved in running down the Qtr mile???
Are there any days where the strip is just for Skyline Australia members etc.. (EG. Dyno Days) that get organised?
I would love to take it down to Eastern Creek and try my luck... Can anyone tell me if there is a specific day (like every month) that you can run your car or is it every night.. etc..
also is it any different launching on a drag strip to street??? I've heard tyres stick better to a drag strip...
Thanks
Rob
At Eastern Creek they have off-street drags every second wednesday. The track does have better grip because
- the track is warmer from the other cars that have raced before you
-your tyres can be warmer cause you can do a fully sik burnout as you come forward to the christmas tree lights
-and finally the EC staff put some crap on the track to help it grip more so yes you can launch a lot quicker on a track than on the street.
OK as for the actual Drags, you need to be there between 3:00pm and 6:50 pm to be in for the drags that night. Its $45 per driver and $35 for the second driver if you have one.
Its on the second wednesday of every month and a fornight after that.
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
