Hi, has anyone tried to swap the front seats around in a R32 gtr or other skyline?
I was thinking of swapping mechs over from a passenger seat to make up a good drivers seat. Its much easier to find a pasenger saet in good condition than a drivers seat and are usually cheaper. From what I can see, the base and rear of the seats are the same, its just the rails and recliner mech that are different. Would it bolt up?
https://www.sau.com.au/forums/topic/139224-swapping-front-seats-over/
Got a set of GT-R seats sitting here, so I just had a look.
The side of the seats which sit near the tranny tunnel are angled slightly upward to accomodate the tunnel.
If you were to swap the gear straight over, you'd end up with one side of your bum higher than the other.
You could probably overcome this with some custom rails, or spacers might do the job, it's not a HUGE difference, it's only a couple of centimetres.
Other than that, I can't tell if there'd be any major problems (but I haven't pulled them apart, and don't intend to)
like i said above. it may be possible. anything is possible, but it's no where near being viable. the important parts of the seats frames are welded. let's say you clear that hurdle and manage to swap the rails and frames over. now you have seat belt buckles on the wrong side of the seat, and adjustment on the wrong side of the seat (and only on one side, cannot be swapped).
but i guess if dark could swap his recaros perhaps ask him how to do yours as he seems to think it's the same? I may be wrong but the six SKYLINE (we are talking about skylines aren't we? not integra type R's, or EVOs) seats I have in my posession all work the way I've described (4 x GTR, 2 X GTST).
As I said you could remove the drivers seat with the damage cover, take the cover off. have a trimmer repair the foam a bit for you, and then buy a cheap passenger seat (always cheaper than drivers), rip the cover off it, and give it to the trimmer to re-fit. that is going to be the only time and cost effective way to do it. unless you want to re-trim in non-factory fabric.
The seatbelt buckle is attached to the rail, not the seat.
If you swap the rails over, the buckle goes with it.
walk out side and have a look at your GTR seat mate. the buckle screws into the side of the seat. but if you can tell us all how to swap left and right GTR seats then i'm all ears. :D
YIKES! I don't know what that set-up is but it's very different to the 6 R32 seats I have here (4 X GTR and 2 X GTST). I will post a pic for you. but that set-up is not standard. I'd say the seats you have there are modified from standard.
no worries. i'll snap a few tonight :D in fact. see that little cap/bung thing just above the line of the metal strap the buckle is mounted on? that's where the buckle is normally bolted too.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
