yeh im going either the gtss or gt2860 both make good power,and good response ive heard
Im thinkin of doin the same there Gunner i was sweatin on the GT_RS's but from what ive heard the 2871's might be the same laggy but good power from 4grand onwards
Hi mate i have them on my gtr and it made 510hp at the wheels on 22psi and 345kw on 17psi at the wheels they come on boost around 3000rpm and make strong power all the way to 8000rpm they work great with the right set up i have all the dyno sheets if you need any more info drop me a line thanks Jason
what else have you got in your motor?? stand 2.6L? cams?? see 3000rpm is not too bad...care to share a bit more?? cheers
thanx guys, just i thought this thread was dead
coming on boost is what? = 1psi, 20psi?
Loaded up on a dyno on 4th or on the street?
There is no way your going to see anything decent before 4500rpm on a stock capacity RB26.
They are 400hp turbos, not 300hp GT-SS or that ballpark turbo
Again, is that loaded up in 4th on a dyno?
Or are you seeing this sorta thing with a roll-on in 3rd.
Its hard to gauge and compare the two as they are totally different to each other.
Not saying your results are false or whatever, just trying to get an accurate picture
frankxinyu - whats your use for the car?
as topic states, is anyone using twin Garrett GT2871s on their GTRs? if so, how laggy are they? and what kind of power are they putting out?
cheers guys
frankxinyu the garret Gt2871 are basically the HKS GTRS turbo and are quiet common on the rb26 but they have had mixed results. They do make more power than the 707160-5 gt2860r but not by much and the turbo responce loss i believe doesnt out power gain. The best results gained fromt the HKS GTRS/GT2871 have been on stoked rb27/28 or rb30. You find it hard to beat the garret Gt2860R 707160-5 or HKS 2530 for alround twin low mount turbos.
Pete
This is the -5s at only 17psi with basic tune as the injectors are 100% duty so by the time we fit bigger injectors and run 24PSI with a full tune i really cant see the point in looking past these turbos for a dual use car and the price it right. RB26 std stroke and head,260Poncams and single throttle kit on stock intake so the engines not wild,shows how good the turbos are.
Boost controller is now sorted so boost is now earlyer and flatter.
i do wanna maintain the street drivability, but it will see some track days.
by talking to another owner who is running twin GTRS on his stock RB26, these turbos are way too laggy on the street....i think i am going to stick to GT2860s-5
thats awesome figure....
the thing is these 2860s are so cheap nowadays.. they are cheaper than the GTSS ones, yet still make more power.....
To a large degree the jump from a 60mm to a 71mm compressor is going to affect the boost threshold because you have essentially the same sized turbine and housing with the same exhaust gas velocity trying to spin them up .
Lots of people ask me what is the next step up from the bigger trim 60mm compressors ie 2530's 63T or the high tip height 60mm 62 trim from the GT28RS/2860RS . So next up in Garretts GT range is the 71mm wheels (GT 35 comp series) which my list shows three sizes .
1) 71mm 48T , 49.25 inducer diameter , 4.75 mm tip height .
2) 71mm 52T , 51.20 inducer diametre , 5.00 mm tip height .
3) 71mm 56T , 53.10 inducer diametre , 5.00 mm tip height .
The larger trim and exducer tip height wheels have greater pumping capacity but it comes at a price , moving more air for the same wheel rpm means they need extra power to drive them . If the extra shaft power is not available then we need more engine revs giving more exhaust gas velocity to power the turbine/s . Basically the big trim/tip height wheels with the same turbine force a slip loss effect of the exhaust gasses round the turbine blades . Its a lose lose lose situation because boost threshold goes up , exhaust restriction goes up , detonation threshold comes down - backpressure if you like forces exhaust gas reversal back into the chambers in the overlap phase so charge dilution and preheating as well as pumping losses . All biggies .
Note in (1) above that the 48 trim 71mm wheel has obviously a smaller inducer diametre size AND lower exducer tip height . This is the next incremental step up from the 60mm GT compressors and will generate a bit more airflow (maybe 3-4 lbs) but have the least negative side affects of the three 71mm compressors . I don't think I'd go past this stage if at all on a standard capacity RB26 because its already starting to turn laggy and getting a bit hot and restrictive on the turbine side if really pushed . Probably more to be had from porting and cams with less trade off . 2860's and 2530's seem to be the sweet spot and after that really need larger turbines to compliment the larger compressors . This then really pushes the boost threshold up and increased capacity is the only way to help bring it back down .
Cheers A .
Edited by discopotato03
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
