Hi Guys
just putting up this second group buy for the HID kits
Now that i have the exact kit installed i can let you know more about them
i have been told from the supplier that there are a few more kits that can be sold
Supplier: Slick Auto
Gb end date: 31/10/06
they are
3 x H1 6000k
4 x H4 6000k
1 x H3 6000k
the price is the same as b4
$220 delivered
if you are around the sydney area you can see how the kit is as i have it installed in my car
it is a plug and play kit comes with the relays
and you dont have to cut any wires like people say to put in a resistor
also has the samsung IC
good quality kit both water and dust proof
let me know who wants in
here are the pics of the kit
https://www.sau.com.au/forums/topic/139336-gb-2-hid-kits/
  • Replies 41
Hi Mate,
Just a few questions
Can you confirm that H1 will fit on an R34?
And is the Light white or blue in colour when you turn the head lights on?
If it fits an R34 and the light is white, then you can put me down for a set of H1.
Cheers
Woldo
https://www.sau.com.au/forums/topic/139336-gb-2-hid-kits/#findComment-2596704
Hi Mate,
Cheers
Woldo
if the standard bulb of the r34 is H1 then it will fit
the color of the light is white
you have to find out which bulb you got take one out and take to a auto shop and they will tell you
https://www.sau.com.au/forums/topic/139336-gb-2-hid-kits/#findComment-2596774
Thanx mate
Will get it checked out and let you know.
Can you put one aside for me for now tho?
Cheers
Woldo
https://www.sau.com.au/forums/topic/139336-gb-2-hid-kits/#findComment-2596851
where in syd are ya mate?
any 8000k available?
im around the liverpool fairfield area
6000k only man
they are the most common that is why the importer got them in i was told
also you get defected with the 8000k because it is too blue
https://www.sau.com.au/forums/topic/139336-gb-2-hid-kits/#findComment-2608226
So it's not hard to install these lights in my R34 GTT? Put me down for a set if so.
all i did on my car was take the H1 standard bulb out put in the H1 HID bulb and then plug in all the connections and they worked
if you are from sydney i can show you when you pick up item
thanks
https://www.sau.com.au/forums/topic/139336-gb-2-hid-kits/#findComment-2609212
do you have pics of your lights nismos15? preferably pointing at a flat surface?
i've got a kit in my R34, and the light is SHITHOUSE. Don't know if it's like that without having the OEM parts, or i need a new kit
https://www.sau.com.au/forums/topic/139336-gb-2-hid-kits/#findComment-2612371
whats the go with low and hi beam, which one do you replace?
i'm guessing the Hid is only for hi beam. so what do you do to match the low beam, parkers and fog lights?
just let me know what the go is, i've got the money waiting.
cheers
https://www.sau.com.au/forums/topic/139336-gb-2-hid-kits/#findComment-2614179
these Xenon kits aren't really for hi beam, it's for lo beam.
Aftermarket HID kits aren't designed for hi-beam, because they don't really come on instantly, and take a little while for the light/colour to stabilise.
only the more luxury marques are releasing bi-xenon recently, last couple years. And i think even then, it involves having a bit of a shield over the hi-beam light
yeah, you can put some really white/blue halogen globes in if you wanted
https://www.sau.com.au/forums/topic/139336-gb-2-hid-kits/#findComment-2614191
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
