  • Replies 41
i believe normal r34s run H1s but for some reason mine run H3s....wats the issue here and do u no which i should use?
dude doenst really matter what bulb your car has just change it with the one thats in it
if it runs a H3 bulb change it to a H3 kit
you might have H3's as you might have the halogen headlight assemblies? Early on in the R34 compliance stage, the entire headlight assembly was being changed. Now they just modify the Xenon assemblies.
either way, unless i see some pics... R34 owners at least will prob be quite disappointed with any HID changeover.
You really need the OEM parts... but again, waiting on pics.
man thats bs.....im so angry that they pulled em out far out. where can i get a set of the original xenons?
i hope i can count on u gohan to point me in the right direction with what kind of xenons i should get lol. i dont realli know why but i feel like H3s aint as good as the original h1s.....correct me if im wrong
you're wrong.
there is no different between the globe types, and what kind of light they produce.
if you had H3 in the left, and H1 in the right, you wouldnt notice a difference.
you're wrong.
can u explain why they converted my h1s into h3s?
s15 run projector headlights, yes?
projectors have a nice clean cut off, and are best suited to Xenon bulbs. Hence 99% of factory Xenon headlights are put in projectors.
R34's have reflector assemblies. Do your headlights have the word 'Xenon' embossed anywhere?
When was your car complianced?
original globes wouldn't even be H1's. They would be like D2R Xenon bulbs. Originals weren't even halogen's.
nismos15, could you take a pice of your headlights pointing at a garage door or wall?
do you have any pics of this kit in a car without projector headlights?
i have the word Xenon right under my buld....my car was done back in feb
posted some pics up of my headlights here
http://www.skylinesaustralia.com/forums/in...howtopic=140889
Edited by anDru
i have seen the 2 bulbs together there is not much difference just that the part that the H1 bulb sits on is different to H3 one to fit different headlights but the light looks the same
im not to sure with the r34 headlights but if you like a h3 i can get one for you no probs
hey which ones do you have your s15? as gohan said the projectors have a nice clean cutoff, does this still apply with the xenons?
ie the light pattern on the road looks the same as normal globes, besides being brighter/whiter/etc of course?
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
