got some parts left over from when I had my 32 that a mate was meant to be buying but this never happened so Im selling them here
Trust TD06 20G 8 cm T3 Flange Interal Gate
$1,250 bargin
looks at Roy
Edited by 1400r
https://www.sau.com.au/forums/topic/139369-fs-trust-td06-20g-8cm/
what sort of difference would the cams and cam gear do??
264s will give you better midrange -> top end
so you'll lose a little bit down low, but not as much as 272s
cam gears will just give you adjustability
as you should know trust turbos are only oil cooled not water cooled so
you need to block your water lines off or join them together
and this turbo only has the oil drain attached so you will need to buy the feed line
http://website.lineone.net/~jon_ed/Turbo_Table.htm
not sure though as it lists it as external gate which its not
430ps
430ps
I have a Trust turbo and it's oil and water cooled :)
stock manifold yes dump no
"No..?
Most are oil and water cooled, despite not being ball bearing"
eh whatever first Ive heard of it must just be the small stuff thanks for helping with my sale though :P
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
