  • Replies 58
  • 4 weeks later...
Just so you know that now days it costs so much less to buy a GTR and chop the front diff off/remove drive shaft and abs then turn into RWD, to the cost of engine conversion in GTSt.
Unless you have got $$$ that you dont want to spend it on other things. :D
