uve got a consult interface right?
datalog from as soon as u start car and post here.
does it make a difference if u allow fuel pump to prime longer (leave car on ign on/reds for a few seconds before cranking)?
and do what i said in previous post
No I don't have a consult interface.
I have reset the ecu and let it go on diagnostic mode, but deciphering the beep codes is difficult.
I tried going to Nissan and their interface supposedly doesn't work with 'imports'.
Wouldnt mind getting my hands on an interface and seeing the log...
UPDATE: Just as an update though - a few days after I cleaned the AAC valve I have noticed the idling has improved. It is sitting around the 1K mark now as opposed to 1.5k.
The only issue now is starting it when cold (it still needs a bit of throttle to get going). I suspect this to be a leak somewhere. Havent had the chance to investigate further.
If anyone has had similar issues and has fixed it feel free to post ur experiences.
  • 1 month later...
  • 10 months later...
Bump, any more ideas? I need to get this sorted...
Dragging up an old thread here but I have had the same issue for about 4 years, when I bought the car it was fine then one day it was just really difficult to start. I had the fuel pump checked, AAC valve, Temp sensor, changed ECU's, injectors cleaned, even had a modfied plenum put on there for a while. I'm going back to the thought that it may be my injectors, I have a feeling that they may be leaking from the body of the injector. If it was say the AFM or serious issue with the fuel pump then I would be experiencing issues when the engine is on load or when boost comes on. I have also noticed ever since this issue arose that my fuel economy has gotten really poor, 350km to a tank. The only mods I have are a pod, 3" exhaust and FMIC, so I dont see how that could kill the economy.
my car also struggles to start when cold ever since i changed from the stock fuel pump to a bosch intank item. Even with considerable priming (ignition on for about 5 - 6 seconds) the car cranks and struggles. Once it doesn that it turns over fine. I ve had the fuel pump taken oout and tested and it flows fine. The instal is also fine so i to am scratching my head at this. Basically whats happening is when the car is switched off the fuel lines lose preesure with after market pumps and the fuel drains away. Problem is it doesn't seem to pick up enough even if you prime it to be able to start first go. IT starts fine the second time you go to start it as it has built up some pressure from the first time. I might see if a one way valve of some description will help this problem if i fit it to the fuel line or something.
funny you started this topic i was about put the same thing up im having the same problem with my 32 i just got it back from graeme west two weeks ago where the problem was ment to be fixed but is still playing up, good to see some different pointers!! mind you its going back in to West this week cheers guys :P
This might be a bit off but could your battery be dying or too small as it seems to only be a problem when your cars starting? If your battery cant hold enough charge/supply enough current during the cranking process this would result in the poor/reduced fuel pressure delivery during intitial stages of priming the fuel lines etc.
Check the voltage over the fuel pump when cranking, the fuel pressure and go from there
All good thought lads,
I have a 32 with the same issues however I can count the fuel pump out as I have a brand new one and AFM :)
Something that hasnt been raised yet is the cold start idle valve....
Just a question:
When your cars eventually start do they idle up around 1.5-2k for a minute or so or do they go straight to the 1k or there abouts?
The cold start thing is a mechanism that works like a line that gets blocked once the car is warm. When the car is cold the line is open to give more revs to start the car... when the car is warm the line closes.
When you start the car it should idle high for a little while... when I first bought my car the idle was at about 2k constatntly and it was due to the cold start valve being constantly open making the car think it had just started all the time. When this item is faulty or old as most are the heat sensor no longer works and the valve does not close and bring the idle down. It goes both ways when they are buggered they can be open (high idle all the time) or closed (normal idle all the time causing hard cold starts).
My suggestion is that the cold start thing is constantly closed making the car think it is constantly warm already... and therefore not giving the intial revs to bring the car to life so to speak.
The cold start is located (looking at the car head on) on the left hand side of the engine bay below the intake manifold.
Any thoughts...
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
