Saw top Alcohol for the first time. All I can say is woooow. Phil Reid was sitting on the line and I expected it to be fast but wholy hell. Your whole body shakes. Even my vision shakes. Just amazing.
What sort of power are those cars putting out? 5,000hp?
If you haven't gone give it a go just for a couple of hours. I wouldn't call it exciting though it is an eye opener.
glad you enjoyed it. ITs great sport that has come along way in oz in the last few years. I remember when I was a little kid you would do good if you saw one good pass out of a whole meeting, and rarely a side by side pass as the cars were unreliable... These days they have more power, go faster, and have more passes its only getting better...
The more support we show these guys the more racing we will see, thanks for posting your experiences!!
Hehe, glad you enjoyed it!
I've taken 3-4 first timers to see Top Fuel in the last year or so .. it never fails to amaze! You cannot describe it .. has to be experienced!
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
