  • Replies 208
Still need a few cars like 33 and 34GTRs, first post for what is needed still. Also post if you want it after small car sunday or another weekend. Will get out and see if i can find some good spots and post pics.
i recon we got plenty of cars if every1 turns up that has put there hand up ...
im easy for what weekend i just dont want to be out late if its the weekend of scs due to my daughter comming home that weekend and ill probably have to get nanny to pick her up but she will want me
Took these pics at henley tonight around 8pm, so i think that around 6pm should be good for sunset shots, on SCS after the show and shine.
Anyone who wants to come let me know, will PM everyone in next couple of days, need to find out if heslo is getting his mate and if everyone wants to try and get HPI or Hot4s to come out.
dang and circle work is soo much fun
isnt that wot a beach is for
wot about maslins :laugh:
lol.. I grew up down south with Moana and Silversands beach at my disposal.
Went to the extent of chipping in with another 2 mates and bought a cheap old Galant, used it as a little rally car. Awesome fun and experience and ended up throwing a rod. :)
Try to grab a tripod or something to sit the camera on then change the shutter/iso speed. You can grab some awesome night shots that way.
If it throws the white balance out be sure to set it manually,.
I took these two shots on a cappy HP 735 3.2mp Camera. Shutter speed at night makes for some very nice pictures. A good SLR also makes a hell of a difference. My sister is a professional photographer and the pictures her Digital SLR takes are simply awesome. You really see how the average camera loses the crisp realistic look of a photo.
so gts33t i take it you have a plan for the day
where not all gunna be there @ the end of scs deciding where we should go as i really dont want it to take too long which i can see now it will i think sat evening would be a better time... but thats my personal preferance
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
    • It ended up being that orientation of the float hub in relation to the clutch disk, when I installed it, I heard a loud click and being stupid, I decided to not take it a part and check it. The hub didn't properly align with the clutch disk and was causing the issue. Definitely an odd one! Dahtone Racing was able to fix me right up, stand up blokes!
    • Right, but I'm saying on the stock ECU measured airmass from the MAF is no higher than stock. So it's accounting for the higher flow rate iso-manifold pressure. You just have to keep turning down the boost until you're within the stock tune's load scale. If you run off the end there's no telling what will happen. This does mean there's zero benefit to the turbos you're running vs stock, if anything it's just a straight downgrade because the transient response is worse, you don't even get the ECU's boost solenoid helping to pull the wastegate closed during initial spool, and peak power is only whatever the factory map can give you before you hit the R&R corner. On a -9 I would bet that you would have to change out the wastegate spring once you have a real ECU and you're tuning it for real. I'm not saying this is a remotely ideal state of affairs, it's just a way to keep it driveable until you can get a proper tune done.
