  • Replies 130
Originally posted by whatsisname
I don't know the full details yet. I'll let you know when I do.
Reason I say this Matt is because AFAIK the Microtech doesnt have individual cylinder fuel trim control, hence 6 would be running the same pulsewidth as 5 and as 4 etc. etc. As for air distribution in an RB manifold? Generally 6 will receive LESS air than cyls 2 and 3, making it inherently richer. You will more than likely find that 6 has been running physically hotter than the other cylinders, due to the Skyline cooling system design, which has pushed it over the detonation threshold. Ie. it detonated to death, rather than 'leaned out'. I may well be wrong though.
Yep your right mate, the LT12 doesn't have individual cyl control. What you've explained, re 6 running hotter & leading to failure, sounds quite feasible. I'll post up the exact findings when the motor is apart.
Could the cause be a high pressure drop across the factory fuel rail and therefore no. 6 injector gets less fuel pressure and may have pushed it over the safe AFR edge? I would say the harder you push the fuel pressure, the greater the pressure drop.
Martin, what ECUs has individual injector control? Have you seen high pressure drops across RB25 fuel rails?
I've seen on a number of tune shop designed items, the fuel feed line is in the centre of the rail, thus ensuring more even fuel delivery for each injector.
I will be thinking serously about a better fuel system when I bolt a bigger turbo on I think (as per Martin's HPI story some time back re RB25 injectors). Either straight fit SARD or new/better rail with whatever injector we come up with.
Sorry for hijacking thread, should be in Matt's rebuild thread!
Hang on guys, the problem with Whatsisname's motor was nothing to do with the Microtech.
I just asked, what other ECUs have individual injector control?
What if it did, how would you measure AFRs for each cylinder anyway?
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
