I'm about to buy a Power FC engine management for my 33, and I also need a boost controller. My two options :
(1) Buy the Apexi Boost Control Kit for Power FC
(2) Buy a stand alone Boost Controller
Wondering what is the best way to go...
-Apexi Boost Control Kit = integrated system, only one controller
-Other Boost Controllers may have more features and easier to change boost profiles?
-Does having the boost control built into the ecu allow for better tuning?
Your opinions?.....
Thanks Paul,
I had read your tutorial a couple weeks ago, but re-read the points you just noted.
From the sounds of it, the PowerFC with Boost Controller allows you to:
-setup 4 profiles to "quickly" select from (how quick? how many menu options do you have to go thru to change profiles, not as quick as a dedicated boost controller which is easier to navigate?)
-set maximum boost
-set duty cycle
I've heard of boost controllers being more powerful than this, and being able to adjust your max boost and duty cycle for different rev's, etc. I'm new to the world of turbo's, but surely a boost controller with more 'tuneability' would give better results?
boost should be a set and forget device
theres no need to constantly fiddle and change crap
to change profiles takes about 3 seconds
MAIN MENU, SETTING, BOOST, CHOOSE PROFILE, PRESS PREV
thats it. theres no need to do that on a day to day basis.
run the most boost you can safely on your engine and components.
boost controllers are often given the complicated "badboy" concept but they aren't all the do is trick the wastegate in its simplest of form.
get on with driving the car, it doesnt have to be this difficult
but why would u do that? why not just run the highest setting you can do safely all the time and use your foot to control how the car drives.
boost doesn't use fuel, you pushing the accelerator pedal does
and if you plan on running that little extra 2 or 3 psi over your safe level then its likely to go bang or just dial in more heat as the compressor is probably out of effiency
whats to not like about it? you dial in the boost and its done
i brought a hks evcIII long before i knew anything about the FC
and if i had the choice again i would have done the FC kit for sure
you also get to use boost in all the correction tables as well as have boost under MONITOR on the hand controller which is very handy.
I would probably buy the Blitz Dual SBC next time around as it has the Anti Waste Gate creep funciton where as the PFC Boost kit does not.
My boost curve isn't as flat as I'd like it either.
BUT: having said that, I can still make 1 bar by 3000rpm with my set up so I can't really complain, and the flattening of hte curve up top isn't really going to make a huge amount of difference.
Maybe it's just the hunt for perfection........
The big advantage I find with the PFC Boost Control kit is that it enables a number of correction tables to be activated via the Datalogit software. If you use a stand alone boost controller you will need another map sensor for the PFC to activate the tables.
Plus with the Datalogit you can use boost to trigger other items, for example intercooler spray.
:P cheers :(
:) cheers :rofl:
Unless you are using a D-Jetro where you have the pressure sensors already there.
Rice NAZI's at it again! Rofl - jokes
I bought a Blitz SBC iD III EBC, cus its got some massive solenoids, the twin unit is at least 6 times larger and heavier, I figure this gives the "zero gate creep" feature someone mentioned, plus better control at higher pressure levels.
Iv read stories bout killer boost spiking issues with other units…Greddy, Apexi etc.
I agree with Paul, i don’t want to be messing with sh1t, thats WHY i spent some $$ on a half decent EBC now.
If i change the ECU, im not in this position, trying to find something to control boost again, boost will always be controlled by the unit regardless of whats happening around it.
A few Hobbes switches should fix the "lost output" on the FC, you just loose any fancy look up table trigger the FC & Datalogit mighta had, im not sure.
SydneyKid: These "enabled look up tables" what do they control, and are they simply enabled by a MAP sensor being connected to the FC? ….
I got a bad feeling this threads guna make me feel like a ricer. Come on, whats some extra carbs in a day
Ta
- M
the pfc faq in my sig tells you how to use a map sensor and the harness to just get the boost reading on the hand controller. once it has the reading the tables will work. so yes u can go access to those tables without the complete boost kit. the sensor is a denso map sensor (part no# in the faq) and the harness is another $20 part from any apexi supplier. the official apexi sensor is about $180
inj vs air temp vs boost
inj vs water temp vs boost
boost vs ign sf
boost vs ign sf
Beat me to it Paul, so all I can do is add for GeeTR's benefit. I am not sure how a hobbs switch is going to facilitate an injection correction table based on boost and air temp. Let alone boost and water temp. Or ignition correction. That's why I use the PFC BCK. Otherwise I have to buy ANOTHER Map sensor and plumb/wire it up. You can't simply parallel up the outputs from the stand alone EBC's MAP sensor, it upsets the voltages.
Interesting side note, I had a car the other day with really crappy boost control plus it was difficult to tune, more than just the boost variations. On investigation I found it had 4 map sensors all T’d into the fuel pressure regulator vacuum supply.
1. Standard map sensor for the dash
2. Aftermarket map sensor for the ECU, with a really long vacuum hose going into the cabin and plugged into the ECU itself
3. Aftermarket boost gauge map sensor
4. Aftermarket EBC map sensor also with a long vacuum hose to the firewall where the MAP sensor was mounted.
There was so much air in the vacuum system that it was buffering the signals. Hence the EBC was getting slow response signals from its MAP sensor and the boost fluctuated as a result. The poor old fuel pressure regulator had to wait for the vacuum changes to equalise in all those hoses before it could correct the fuel pressure, hence the difficulty in tuning the A/F ratios.
Tip, don’t T into the FPR vacuum feed for MAP sensor signals if you want stable fuel pressure.
:P cheers :D
Edited by Sydneykid
:( cheers ;)
Hey SK,
Sorry, I meant using a hobbes to trigger a IC water sprayer.
Yah, I woulda thought stealing the output from the EBC’s MAP sensor woulda been fraught with danger, I would like to keep the smoke in.
Would never dare add volume to the tubing that goes between collector feed and FPR
Now I must learn how the extra tables Paul spoke of , work their way into tunning.
Cheers everyone
- M
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity.
    • 100% the factory sender is tapered, that is how it seals (well, that and teflon paste or tape)
    • Thanks folks - I've saved a few links and I'll have to think of potential cable/adapters/buying fittings. First step will be seeing if I can turn the curren abortion of a port into something usable, then get all BSPT'y on it. I did attempt to look at the OEM sender male end to see if it IS tapered because as mentioned you should be able to tell by looking at it... well, I don't know if I can. If I had to guess it looks like *maybe* 0.25 of a mm skinnier at the bottom of the thread compared to where the thread starts. So if it is tapered it's pretty slight - Or all the examples of BSPT vs BSPP are exaggerated for effect in their taper size.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
