  • Replies 221
Posted Images
Can some one PM me their mobile number so i can get in touch with them on the night to find out where evryone is...
PM sent.
Am i still allowed to come if i bring my 350z? I am getting a brand new one on Friday and i want to take it for a cruise..Common am still nissan though..
Of course.
How do you think we all met each other?
i guess so... sorry wasnt thinking too much last nite when i posted, was way too tired after working a 14 hr day.
well im in for the cruise. ill be in a white r32 gtst.
lol sum guy with a laptop told me about this at 3am at orangegrove maccas/kk last saturday night. Sorry dude forgot who u were, thought u were selling hot laptops in the macas carpark hahaha.
Do you have a licence/working car Loz?
was it me? I was there on a friday nite I think with a laptop drunk off my face lol I spoke to mintie and elushun and few others who got back from cruise like 5 mins after we got there
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
