i did clean it with a dremel slightly, is ur's a s2 motor?(maybe i got a s2 motor, i duno) can any1 else answer this?
yes car is a series 2. and ignitors built in coilpack. but i didnt think that would have mattered?
  • Replies 58
ya mine are like that to.. all shiny and clean looking... i was disapointed cause i was hoping theyd have heaps of crap on em :D
mines a s2 also.
just had a look at mine a while ago and it looks metal as well. unless the actual 'metal' is junk and once cleaned it comes up with the copper look.
going to my friends house saturday morning ... doing 2 s1 33's at the same time... will let u know how it goes... no pics sorry :S but will tell ya if its a fix his misses day and night mine only misses in the cold night
got pics.
The coil that was arcing out the most did have the most crap in it.. But it isn't that bad. :S
I'll now clean them up and see how it goes.
You can see the darker off looking colour. The camera lightens it up quite a bit more but the color is quite dark.
Cleaned up the small amount of crap inside the coil..
And noticed a cracks on all the coils, some noticeably cracked, others didn't look cracked but under the camera they obviously were starting to do so. Quite difficult to see but the camera in macro mode shows the crack very nicely.
And fingers crossed.. the silicon does something.. Either way I know I'm up for a set of coils and cleaning the inside in my case isn't going to jack. :devil:
Mine have been on the car for 220,000km's + what ever it was wound back. They were very clean in side the coils apart from one that only had a bit of gunk as posted above in a previous post.
They all had cracks in the same place. I was unable to find any others but its quite possible there is one under the bracket that holds them to the larger bracket.
good work mate.
keep us posted on how it goes.
the silicon might melt, so keep an eye on it somehow.
if it does melt, you might get away with pushing some araldyte into the crack as much as you can.
A quick google - silicon has a melting point of ~1410degree's c.
http://www.google.com.au/search?hs=nAi&amp...earch&meta=
Hrmmm sounds a tad high as I've melted silicon in the past with a soldering iron, maybe 'pure' silicon? :devil:
As I can only really see the first 3 coils, number 2 with the big crack in it still sparks and can be seen at night :laugh:.
Number 1 and 3 that were only starting to crack don't light up anymore. I might pull them out again after a little driving and see if I can see arc marks and how the silicon is holding up.
just pulled mine out today.... originally they looked like the first pic posted on page 1.... grey crappy looking etc... could not see color... NOW they are nice and coppery shiny woooot lol had a few cracks used the industrial grade stuff ... 203C continuasly see how it goes when it dries and i put them back in!
All though I can still see the coils arcing out once warm I am no longer getting the pop/miss fire.
So it has worked, I'm not running much boost at the moment (12psi) so with more boost it may very well fall on its face again.
A new set of coils are going in none the less.
A mate of mine runs 16psi through a highflow and thats popping badly where a massive power loss is felt. I'll silicon up his in a week or so and let you all know how it goes. :)
Also.. The silicon is holding up perfectly fine. No peeling, melting etc.
I did make sure I cleaned the coils well prior (prepsol)
Guest Rotary20B
A mate of mine runs 16psi through a highflow and thats popping badly where a massive power loss is felt. I'll silicon up his in a week or so and let you all know how it goes. :(
What sort of silicon are you guys using? How long does it take to dry etc?
Mine misfires badly around 4k up running around 12psi.
I pulled the coils out on the weekend, couldn't see any cracks, mines looked like the pics on page 1 to begin with, cleaned up well.
Put them back in, not much difference, I did notice it was a little better, still can't give it full throttle though.
With the silicon and cleaning the coils, what are you gapping the plugs, .8 or 1.1?
Plugs must be gapped at 0.8mm
The cracks are quite hard to see. I missed them at first. The ones that I thought were not cracked under the camera showed as they were indeed.
I think they must also crack some where else as I siliconed up the crack that I could see yet i can see it arcing on the opposite side.
Either way its fixed the pop for me for the mean while.
    • This is amazing. Love that you’re giving the boys an intro to cars and off the screens. They probably have an insta for the car and build posts on TikTok for their mates.
    • It is.  Your car works fine with the tank full. If you drive like a Nana it works fine.  You give it a boot full with half a fuel tank, you get surge.  It 100% is a fuel surge issue. Maybe have a look at installing a Hydramat if you don't want to install a surge tank.  https://www.holley.com/products/fuel_systems/hydramat/
    • Hanging out in Perth for a conference. Asked for a room with a view… got a view of Bustdown Festival   might stroll down and go say hi to Spotto and some of the hoonfluencers
    • It’s definitely just a problem with my car, as there’s bound to be plenty of 4-600hp cars out there running a factory tank with an upgraded pump and or hanger
    • Ah right, that would be a nightmare as I only get 150ish kms before it starts having issues/half a tank, and yeah if I don’t get into it I could run it completely dry, it’s only when it comes into boost it will start to break up, it also does it in every gear which leads me to believe it isn’t fuel slosh/surge as 4th and 5th shouldn’t have enough power to cause an issue. It’s got me stumped 🙃
