OK for one of my sheets chech
http://www.hyperdrivems.com.au/images/dyno/peterblight.jgp
I know the boost moves around a bit but theres a bit of story behind that as i was tuning at 18psi and the shop didn't have time to let me complete all what i wanted to do so we quickly adjusted the boost control to 20psi and ran it (the duty cycle was a little off) another run would have seen a flat boost curve as normal.
as for X boost at X rpm I GOT to say it one of my biggest pet hates (but i will tell you why)
As it is basically is of no real indication because boost is a measure of back pressure and a motor that builds back pressure quickly isn't necessary a responsive motor. What i work on is hp (your more importanely torque) at what rpm because that is what gets the car moving and pins you back in the seat, for example
1/ car 1 make full boost at 3500rpm and 150rwhp at this point
2/ car 2 makes full boost at 4000rpm but at 3500rpm is making 185rwhp
comparing boost to rpm you would say car 1 is more responsive but in the real world car 2 is making more hp at same rpm for less boost and will accerate quicker.
I hope that explains why.
I still believe from all my comparsions the -5 are more responsive that any of it's competitors because of the hp it will make at low to medium rpm and has the benefit of a good healthly top end.
off my last dyno sheet (not the one attached but very similar)
~135rwhp @ 3500rpm
~180rwhp @ 4000rpm
~250rwhp @ 4500rpm
~360rwhp @ 5000rpm
~440rwhp @ 5500rpm
~530rwhp @ 7500rpm
Please i am not trying to get into a pissing contest either i know there are many high performing GTR out there and in no way am i try to say my is the best but simple trying to show the performance of the gt2860r 707160-5 on a mildy tuned rb26
GTR-Dad if you have any question feel free to pm me
cheers
pete
Thanks for the info Pete!
A couple things...
1 - I'd be willing to bet the reason some guys have seen no difference between rwhp and awhp is because they've used a 4 wheel dyno that connects the front and rear rollers so they roll at the same speed. Independent rollers won't work with the ATTESSA computer - it just gets confused. If the fronts and rears are rolling at the same speed the only source of slip is if the rears are losing traction on the roller. Not really a good dyno practice. :) The longitudinal g sensor will quite truthfully report no accelleration so ATTESSA will conclude there's no need to send torque to the fronts. They get a free ride. It still takes power to spin the front roller, but the car gets credit for doing that in the torque calcs. But it's in rear wheel drive.
2 - I too have searched hard for quantitative comparisons between the GT2860R in -5 and -7 trim. My car is a daily driver and weekend road racer so I value responsiveness highly. The math says the -7 will spool earlier and run out of breath sooner. The 300 - 325 rwkw ceiling is OK with me, so I'm planning to go with the -7 trim. I'd be happy to post boost vs rpm and dyno curves when the build is finished - maybe in late March - and would be interested to see your -5 numbers.
My setup will be:
I run a R32 GTR rb26dett
with
Garret gt2860r 707160-7
Apexi PFC and handcontrol
Manual boost control
JUN 264deg 9.7 mm lift
JUN cam wheels
???cc injector
??? afms
Apexi Power Intake
Tomei O2 housings
Turbo back 75 mm exhaust
I'll be tuned for Canadian 91 (RON+MON/2) gas and running 1.2 to 1.4 bar of boost. Should be very close to an apples and apples comparison. I've got no doubt your peak power numbers will be higher, but I'd be very interested to examine the boost vs rpm relationship below 4500 rpm.
Cheers,
Dan
  • Replies 281
~135rwhp @ 3500rpm
~180rwhp @ 4000rpm
~250rwhp @ 4500rpm
~360rwhp @ 5000rpm
~440rwhp @ 5500rpm
~530rwhp @ 7500rpm
cheers
pete
Thanks Pete.
I agree with you completely and will PM with specifics. I can still change my turbo selection (I think) so will be very interested.
In defense of my boost vs rpm turbo performance metric, I assume identically flowing engines. I like it because I can log it without being on the dyno.
Cheers,
Dan
Thanks Pete.
Cheers,
Dan
i had the same prob when picking turbos.-7 or -5 i went the -5 as for the future i would want more than 300awkw. some where round the 380 to 400awkw.. hoping the -5 are the right choice
Thanks Pete.
Cheers,
Dan
It's a nice idea but the only problem with this is the turbos are one of the biggest facts in how the motor will flow. The other main factor is cams and especially cam timing. If you have a look at sum of my old thread you will see i once gain over a 150rwhp tuning with 1 psi of extra boost a little fuel and ignition BUT the rest ~120rwhp of the total was gain by tuning cams (exhaust especially) I do say tho that every engine is different and some gtr only gain small amounts but i have yet to see a gtr not make more hp once cam tuning was done properly.
i recommend the -5 as i have seen to many great results on them, but the -7 are a fine turbo i just dont believe there as well matched to a modded rb26(cams etc). I also had the -5 on from first mod due to turbo failure, meaning i ran -5 on a totaly stock rb26 (std everything bar exhaust, std air box,afms,injector ,ecu the lot) in this from it ran 316awhp(~360rwhp) 18psi and ran 12.0 1/4mile (1.75 60 footer). So i don't believe these turbos are to big for any level of gtr motor mods.
Pete
I've changed from -7s to -5s!
Time to order quick before I change my mind again!!!
It's great to hear from guys who have actually got experience with a particular combo. My only concern was that a daily driver might not feel as snappy with -5s and with -7s. Drag racing isn't my thing and I didn't want to let the desire for big power numbers to cloud my vision.
From Pete's dyno curve (400 hp at 5500 rpm) and description of driving experience, I can see that if I'm careful with the details I'll be able to get plenty of response out of the -5s and leave plenty of room to dial things up as my appentite for power creeps up.
Cheers all!
Dan
Cheers all!
Dan
my thoughts also.good for minor mods and also major mods.can get nice power out of these puppies
Hey gun32gtr.Had the same probs as you in ordering the turbs over xmas.Got them now and went with the -5 model.Getting them put on in feb.From what I have seen on this post they are an awesome choice for the road and can make in excess of 500rwhp.Plenty for my right foot.lol.Thanks for that info on your mods and power level pnblight.It gives me a good indication of what to expect.I will let ya know how I go anyway as my setup is nearly the same as yours.Good luck bro!
please supply pics of u standing there with a sign saying "dont u wish ur dad was rich like mine"
yeh mate never will i order over xmas again im still waiting it bullshit..yeh -5 are the go for sure.500hp at the right foot would be nice.im hoping for 440hp see how motor holds up.
just finished pulling the old ones of.thaNK god..
and yeh thanks to everyone for info
my new speedo gauge turned up today,just want any tips when putting it in.what to be careful of as well.also it dosnt say on the box which model its for so how will i tell if its for a 93 model etc.not for my 89-90 model..
thanks kane
If its for 93 model, i take it off your hands :laugh:
thanks kane
kane if its for a model after an 89, the back will look different to the speedo that come out of ur car. easy to change parts over. any speedo for a 32 is suited, just slight modifications needed between years... PM me for more info.
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
    • You just need a different blue slip shop (preferably one you regularly use as a mechanic), and make sure the coil overs are as close as possible to standard height
    • yeah the sugar refining companies were pushing for the same in Oz originally, all fuels were going to have 10% ethanol to make them "cheaper" (noting, that the loss in l/100 might be greater than the decrease in price). I guess they won that fight in Canadia
