  • Replies 281
yeh im stinging to see what she makes?
does anyone no what boost the 2860r make on the actuator setting they come with?as im not running any sort of controller/
I've heard the wastegate spring is adjustable, and that the factory setting is 1 bar.
That's second hand info, so treat it as such.
Dan
It depends a bit on the exhaust system but if you have a free flowing system with high flow(or no cat)cat you should see ~0.9 to 1 bar boost off the actuators, and a reduced boost level if the exhaust is restrictive at all.
pete
i have justjap dumps whick look to be nice and free flowing,2.5inch in to 3inch stainless dumps,stock gtr cat and 31/4inch titanium cat back. i want to run about 22psi so how should i adjjust them? or should i run a bleed valve
the std cat is going to have a dramatic effect on the system and why do you think you need 22 psi the extra boost doesn't always gain big results the -5 i have found on the rb26 seem to hit a sweet spot around 18 psi and the after 20psi the gains for boost increase fade, so for the extra stress your putting on the engine and turbos it's offen not worth it. 18psi quiet offen can see a healthly well sorted rb26 pass 510rwhp+ but if your looking for figures inexcess of 530-540 your should most likely be looking for a different combo and you'll have to sacifice responce to do so.
As for controlling 22psi you WILL have to buy a electronic controller to get the consistent control required or you will suffer the swings in boost pressure from different temperature conditions which at that level could be dangerous at 18psi a swing of 1 or 2psi isn't to scary but 22 plus 2 or 3psi and your getting very close the design limit of the centre cariridge of 2 bar.
pete
Edited by pnblight
pete
thats the info i was after,so 18psi should see the 320awkw im after or maybe bit less wouldnt matter?
profec b sounds to be ok so i might look into them.. thanks again all
  • 1 month later...
I'll 2nd Seans call on a MetalCat. I bought my GTR with a straight pipe in place of the cat & when I swapped it out for a 4" MetalCat flanged back to 3" to match the exh there was basically no noticeable difference in performance whatsoever.
BTW didn't you lose your licence awhile back?? Might explain why you're in no real rush to throw everything at the car ;)
BTW didn't you lose your licence awhile back?? Might explain why you're in no real rush to throw everything at the car :P
He'll be on the road again, before you know it.
Not when all the parts are ready to put on. :happy: get moving!
yyeh yeh im just getting motivated...4months 1 week till im legally aloud to drive again so ill prob get more motivated then...
still its a pain not even being able to start it and hear the noise of my rb26....grrrrr
Man, i there with you. Mines been off the road for.. *gulp* 12 months. Have a mass of power steering lines to re-route, 12v feeds to run through the cabin, engine oil cooler to finish lining up... all waiting till i can get my tahbin and m.fold - i LONG for the sound of the RB again
It can often be hard to get under the gurl in the ever colder nations capital, to be covered in PS fluid.
At the moment im on a raising rate dose of HiOctane / JDM vids, plus 80's Rally docos' and rides in mates fast rides
Almost there, have faith man
M
Edited by GeeTR
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
