Christmas Cruise Date
42 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 43
Welllll kind of seems pretty clear the winner in the dates so hopefully without to many objections the date for the Christmas cruise will be the 9th of December :P.
Style32 and anyone else who wants to come minus ride I'm sure will be able to find a lift with some lovely sauer :).
Ok just to clarify :):
Date: 9th December
Meeting place: The Museum
Cruising to.. : The cotter for lunch (byo of coarse), some random points in Canberra for some photos, its been suggested mount ainsle, and the brand depot car park.. *shrug* can be decided on the day but bring a camera!
Edited by skyline_babe5
with the money left over from dinner i thought that was going towards some snags, bread and sauce :happy: that way people can just bring some drinks and any fancy food they want to eat
Define fancy food???
Is this like VB or Tooheys Old?? Arrgghhh no that would be classed as drinks........fancy food??, is this a Canberra thing??? I'll have to come now.......just to watch and learn what fancy food is and how to eat it!!!
count me in for sure now! car may even be back on th road this week :P definitly by the 9th providing i don't find something else to break on it between now and than lol
awesome will be good to se you and ur car out its been a while since ive seen it around!
?? you've seen me and my car before?? i've met the skyline babe?? wow when was that sorry if this sounds rude :P
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
