Just ask him mark! PM is nice.. He's got a performance shop he is setting up.. Not sure how he's going on that and whether its operational yet.. but I have the card at home if you want the contact details.
The amount of boost you want to run all depends on whether you are prepared to buy another turbo if you push it a bit too hard and it goes pop. I'm pushing 13psi on my R33 (with FMIC), but of course that is slightly different to R32.
Its all a bit logarithmic.. on the stock turbo, the higher you wind the boost past about 8psi the less returns you get (e.g. 20% increase in boost won't give necessarily 20% more power).
https://www.sau.com.au/forums/topic/14065-want-more-boost/#findComment-285231
yeah no FMIC isnt a prob with 12psi... im running that now... the ECU he swaps over also gets rid of all the limiters :D no more getting to 180 and having the fuel cut hehe
well worth it... i might be selling my FMIC soon...
https://www.sau.com.au/forums/topic/14065-want-more-boost/#findComment-285328
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
