I wasnt racing, I dont race, and if i ever did it would be in a controlled environment with a certified driver trainer. I am a very responsible driver and dont take my license for granted.
No one has to get defensive.
Just keeping you on your toes chris :D
[ QUOTE ]
yes they are chris.. my mums gx awd wagon pwns SR20DE S13s bahaha... the S13 driver was stoked.. and then insisted that my mums car was turbo.. the brakes wer smoking but... left foot breaking FTW..
But we all know SR20de s13 are the bomb to :D .I havent had much to do with the libertys but the turbo ones that i know arent modified.
Edited by R334door
pfft.. is that a challenge.. ive driven liberty RS ADM ones. and they are a dream.. soo good for the age.. but a GTR will own it.. and i can push the 180 quicker around corners now than i could with the GTR.. the fine line between grip and drift..
Ive havent had the chance to compare 180 to a gtr through twisties yet,interesting to see.
i feel like a slide.. wednesday better be on!!!.. archerfield track of course :D
too be hoesnt who hasnt driven fast on the streets.. even our ex premier admitted to it.. bah a role model.?
anyway.. personally i dnt drive quick on streets with others around.. or with anyone in my car apart from my brother.. only out in whoop whoop.. its ur choice. as far as i see im taking responsibility for myself. and have the right to drive where and how i like. but i still choose a place with limited factors. and never around others. i knw that the above comments wernt aimed at me.. but its about time u realise that ther are mature ppl and ur not all perfect and even u speed.. deny it i dare u.
enough said
Amen.
Lets keep the "street racing" talk for another time... Thanks
sorry col :)
just a shout out to ppl who might know a mate that can weld.
just want some minor welding done, mostly on intercooler piping.
anyone know anyone?
alluminum pipping or steel?
lol.. just silicone pipe it up.. im gonna make a whole cooler kit out of silicone oneday. ive seen it before ;)
need him to weld a spout on, and weld on my BOV.
and if possible to supply and weld a piece of exhaust pipe for my high mount setup.
thought if i got some guy to do it it would be cheaper than taking it to muffler men for $500
I know welders in who weld anything, top notch work to.If you will be out tomorrow night i can try and catch up with you somwhere and give you some details.only reason being it that i'll be busy all this weekend.i also know a fitter and turner he does cash jobs as he works for himself.Does me all my custom one off bits for pretty cheap.
Hey,
I wouldnt direct weld on your BOV as its VTA....just weld the adapter plate and bolt the bov onto it.... just gives you the option to remove ur vta bov incase you need to, hehe :P
Good luck though, sounds like a good project :)
Cheers
Hey,
Cheers
Oh i thought it was a aftermarket bov.If its the original i wouldnt touch it at all prob out of cast plus the internals have got rubber and maybe plastic so more than likely they will melt and wreck the use of it. If it is a aftermarket one you might be able to pull it down for welding.What type is it?
Nah, his BOV is aftermarket, but its VTA....and if it was direct welded it wont be coming off...Say he wants to install the stock one for a week or something, at least he has options if you weld an adapter plate that suits both...
Kind like my GFB one...paid the extra and it bolts up stock.. You get what you pay for.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
