Last time I looked they did...did a really good job of binding up on the dipper at Bathurst and spearing them off in to the kitty litter
Sports cars are a nice handling over all package.....the viper is a large powerful engine attached to a chassis built manily around 2 bits of railway track
LOL RAILS...
did u see the lotus come over the peak too fast hit the strip and bounced off a wall and into the service road..??? 900kg 1.8L toyota engine ftw...the donut king cup thingo..
was a good race.. EVOS wer crazy.. and did u see the FD3S behind everything..?
FD3S are a sports car.. good overall package.. but they are kinda gutless.. like the RX8 bahaha... waste of engineering.
hi all,
im new to sau ive come over from the exa club as i had an exa now i have a skyline and am in desperate need of your help i have a r33 gtst series II 4 door auto yes i know its a friggin auto it sucks yadda yadda yadda anyways i got a bigger front mount a bigger turbo power fc and viper alarm system also window tint and pearled paint anyways i had a loose wastegate actuator and when i fixed it (as boost was coming on at like 5500rpm) it now gets full boost at 2000rpm the car is pinging like a bitch i cant afford to take it to a decent dyno and im looking for a stock ecu and decent boost controller to swap for it. i managed to get the car pinging not so much by self tuning as best i could but just want the stock computer and boost tap if anyone can help me out send me an email at [email protected] please cos im desperate to get my skyline working good btw i live in beenleigh but work at capalaba at bryan byrt ford >_< lol thanks guys.
The power fc needs to be modified to work on an auto car, you CANT run a power fc out of the box on an auto car. Yes it will work, no it won’t work right.
SydneyKid on these forums made a post in the tech sections explaining what needs to be changed to work, he runs one on his auto Stagea
hmm SK is smart.. hes a good bloke..
makes me wonder what he looks like..?? anyone got a picture of him im keen to see if he looks asian with white gray hair and long kung fu mostach
Power fc's dont run on auto cars...
This is true. I think his biggest problem will be with the Power FC.
My advice consist's of the following, seeing i owned a 4 door r33 auto at one stage.
1) Post in the WTB section of the SAU forums and let people know you need an R33 Series 2, Auto ECU.
2) Disconnect car battery and remove the Power FC ECU and hand controller (if it has one) and replace with your second hand r33 S2 Auto ECU.
3) If you already have a boost controller, i'd piss it off pretty quick and reconnect your boost lines into the stock boost solenoid to ensure either of the two items above arent causing the problem.
4) If the problem is still there and your running a stock ecu and boost solenoid, i would then locate another wastegate actuator and replace your current one. If your actuator is allowing your gate to open quickly, your turbo will spool around 8-12psi in an instant shot and give you a massive amount of boost spike.
However, you mentioned you had issues at 5,500rpm (Wastegate not opening soon enough), and now it spools to early (Power FC problem, Wastegate opening to early...Way to early...)
I'd seriously give the above a fair go.
Good luck. :rofl:
Chris
Edited by SunnyCoast
Welcome to the forum.
You said that you had a loose wastegate? how did you fix it? I'd be definitly pulling the power fc out like the others said as they obvously not suited for autos .If you cant pull the fc out for now take a few degrees out of the timing ( get one of your mechanics to do it, thats if you are desperate so it doesnt ping might, make the car not responsive). What fuel have you been putting into it ?Hopefully nothing under bp ultimate.I wouldnt be running any boost controller until your problem is fixed so get that wastgate sorted out or your chances of engine damage will be up there.
Good luck
Good luck
Ditto :D
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
