Do you have to provide your own helmet or do they have ones u can 'rent' out? also what would classify as a non approved helmet?
you have to take your own helmet. Has to be basically adr approved,they should have a sticker saying that, also if a helmat is damaged in anyway like cracked they wont allow it.
ah serious.. how bout i just say i personally prefer the silvia engine and chassis to the skyline so ill leave it at that...
yeah good descrete place aye andy if u need a hand let me knw.
u gonna run a sandwhich plate or a sensor off ur cooler.?
it has a sandwich plate with 2 sensor holes in it :(
Why dont we all organise a meet up sometime, have a bbq, few drinks and get to know eachother?
Seems alot better than having a dig at eachother on this forum....
Anyone?
i suggested this ages ago , well about 4pages.Im in!!
really..?
still waiting for the specs to back urself up.?
log off please key board warrior
anyway speaking of mounting boost gauges in skylines.. this is what i did in my old GTR. fits nicely... being a smoked gauge its very descrete but when ignition was on looked hella good.
Thicker than a brick shit house aren't you. You just don't get the point, for the third time, i'm happy to continue this conversation in a thread thats not in the sunshine coast section. Is that to hard for you to understand? Start a thread, or pm me. Simple as that.
lol who r u anyway.. obviously a major player on the northern beaches..?? well excuse me MR high roller.. :sorcerer:
i just found a new play toy..
ahh performance wise.. u wer saying it was a shit kit before wat was bad about it..?? was it just cause u got a 25t?
you know how the rb25 has the stock oil cooler thing and the rb20 doesnt? i think that was the problem as the lines could not connect to the sandwich plate cause it was too close to the chassis rail
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
