I will definatly be dropping in on the autobarn thing on sunday, have to go out for the sunday drive!
Looking at buying speakers for my r33 what are good splits that will fit flush with the original holes?
Also does anyone know of any really good workshops in the sunshine coast area that really know their skylines?
Some great splits would be rockford fosgate punch, top quality speakers and will provide a perfect and crisp sound. but also depends on you budget...they are fairly expensive, probably lookin at the $200 mark for the pair.
Also for skyline workshop there are a few places. i know of an import place that deals specifically with skylines and other modified/tuned cars in kawana industrial area, sorry i forget the name but could probably find it for you if u like. Hope that helps :). D
If your looking at getting work done to ur imports. there is only 1 person id go to on the sunshine coast and that is marty at MW performance. he has done all my work on all my cars for hte past 4 years and never have fault him once. thats why u see alot of mw stickers going around. he delt with alot of work on my rb25 silvia which made over 260rwkw and my series 2 r33 skyline and the gtr aswell., that aint counting the endless sr20s he has worked on..
if u want his contact ill pm me it. just give him a call and talk about wat u want.
Edited by Sr PWR
I'll second that, Marty does all the work my 34 also. I wouldnt trust my car to anyone else on the Sunshine Coast besides Marty :mellow:
Chris
I'll second that, Marty does all the work my 34 also. I wouldnt trust my car to anyone else on the Sunshine Coast besides Marty :P
Chris
you will have to book in advance as he is always busy.He must be about the only decent and honest mechanic who works on imports 100% of the time on the coast.I got his number etc if you want it
x3. Won't let anyone else touch my car, marty know's his shit thats for sure, and his prices are pretty damn good... the crazy bastard even has a 400rwkw T78 sr20 180sx!
Um close but it is actually a trust T67, and its 320kw @ the wheels.
Uhm no, it's a Trust T78-33d with 16cm exhaust housing, its the exhaust same turbo i had, marty was gonna buy it off me for a spare because it was the exact same. Last time I talked to marty when he got his car back from the dyno it made 380wrw.. they couldn't get a good reading because of tyre spin on the dyno... unless he has changed to a smaller turbo since then.
this was a while ago he might of changed it, knowing him this is quiet possible,either way its one hell of a setup,we agree?
Yes yes marty has spent a small furtune on that car, last time i saw he was putting on r33 gt-r brembo's, got a new carbon/kevlar bride racing seat, new coilovers, trust radiator... not to mention it was bulit buy garage saurus before he got his little mits on it 5 years ago..
Word on the street is he's opeing a workshop in kunda, i'll ask him tommorow about it..
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
