yep. gotta go do some actual work now though which is kinda strange. we're cleanin out an old storeroom that has like 10yr old computers n printers n stuff in it. tip run in the work ute
A group of us are going to meet at the chancellor park woolies at 7:20 for a 7:45 departure to the main meet for the SCC if anyone else wants to join us, if you let me know your comin either pm me and i will give you my number or just indicate in this thread that your keen so we can get a rough idea of numbers so we dont leave with out you as we did last year
Hey,
Just wondering what this cruise is???? Where abouts is it and what day/time etc... Might be interested.
Thanks.
Chris
Edited by SunnyCoast
wes get home and start puttin that car together.
Cars all done, just gota get the window tint done on thursday and put the interior bits back in but the ignition is now all sorted out and the new window is in, big thanks to the big rice man and sir 4door for all ur help and fluids couldnt have done it with out ya's
spewin u cant make it chris it will be an awesome day
See u at the meet shaun
sorry for the interuption, but i come bearing a message...
http://www.skylinesaustralia.com/forums/Sc...rs-t194583.html
Ok to keep certain people happy we will be leaving the sunnycoast meeting spot a little earlier. so instead of leaving at 7:45 we will now leave at 7:30 so youd wanna be there around 7:15ish.
Its great to see a quite a few people are comin from the coast
ok ill be at the meet point too.
Cyas there
Blink... I got a missed call from you at like 1am in the morning a couple of nights ago...whats with that?
Also, i thought you hated cruises?
So ghey..I live like 1 min away from the meeting point..So devo'd that i cant go.
Would you boyz (and girlz) be up for organising a Sunshine Coast cruise? I would be up.
Chris
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
