yep. gotta go do some actual work now though which is kinda strange. we're cleanin out an old storeroom that has like 10yr old computers n printers n stuff in it. tip run in the work ute
A group of us are going to meet at the chancellor park woolies at 7:20 for a 7:45 departure to the main meet for the SCC if anyone else wants to join us, if you let me know your comin either pm me and i will give you my number or just indicate in this thread that your keen so we can get a rough idea of numbers so we dont leave with out you as we did last year
Hey,
Just wondering what this cruise is???? Where abouts is it and what day/time etc... Might be interested.
Thanks.
Chris
Edited by SunnyCoast
wes get home and start puttin that car together.
Cars all done, just gota get the window tint done on thursday and put the interior bits back in but the ignition is now all sorted out and the new window is in, big thanks to the big rice man and sir 4door for all ur help and fluids couldnt have done it with out ya's
spewin u cant make it chris it will be an awesome day
See u at the meet shaun
sorry for the interuption, but i come bearing a message...
http://www.skylinesaustralia.com/forums/Sc...rs-t194583.html
Ok to keep certain people happy we will be leaving the sunnycoast meeting spot a little earlier. so instead of leaving at 7:45 we will now leave at 7:30 so youd wanna be there around 7:15ish.
Its great to see a quite a few people are comin from the coast
ok ill be at the meet point too.
Cyas there
Blink... I got a missed call from you at like 1am in the morning a couple of nights ago...whats with that?
Also, i thought you hated cruises?
So ghey..I live like 1 min away from the meeting point..So devo'd that i cant go.
Would you boyz (and girlz) be up for organising a Sunshine Coast cruise? I would be up.
Chris
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
