u 2 would look mad hot in the porka, josh with his aviators on and his long blonde locks blowing in the wind, and adam arm out the sun roof waving at all the passers by lol
I dont wear aviators :)
I have big "Naughty Corey" style glasses, but white :P
That all depends on how many times you saw me go past..
The time I saw you, I was heading to Mdore
yeah that was the only time i saw u, some fag made me drag all his 52 ceiling battens up to top level of that shops, said they were needing them coz they were gonna be on site but when i got there they were no where to be seen. so i wa slike f**k it il do it myself.
Yeh - Peregain, town of the lazy.
Everyone turns up when they feel like it :P
hey josh, u seen that HZ kingswood up north area, has full purple paint job and white interior and chromies, and has plates "51KHZ" what a pimp mobile.
Yeh thats Matt's. He had the blue soarer with the big single turbo and drift king stickers.
It's ok, has a VN 5.0lt in it or something.
Hey guy just a quick question from your experiance what do you think i should do?
i have just bought a FMIC fixed up the exhaust and need to know what to do now?
i want to take the boost up to around 10 to 11 psi and so i will have to upgrade the ECU or buy a piggy back
i want to get up around the 200rwkw mark eventually.
What do you think?
u take that thing past 10psi on stock ecu....be prepared to hit R&R.
a simple apexi safc will get u to 200kw.
argh ok i remember that soarer used to see it round coolum heaps, that kinga looks ok, but one thing i would do is put some spoker rims on it daytons would finish it off better then those rims they just dont suit it.
Rest and relaxation? lol seriously why wouldnt stocko computer handle around 10-12psi? with supporting mods like fmic and boost controller?
rich and retard. mods + stock ecu= rich.
u push past 10psi, the ecu retards timing and dumps fuel= 1 huge flat spot in rev range
http://www.skylinesaustralia.com/forums/R3...;hl=rich+retard
Edited by r33cruiser
if u install your fmic, and get a boost controller your standard ecu should be able to handle 10 -12psi no problems, probably up to like 14-15psi im sure. with out any other mods. ecu is only better when u are going larger turbo then u need bigger injectors, and fuel pump etc then ecu to manage all that stuff. unless u are going to do that in the near future i wouldnt waste your money on a ecu at this stage.
Thanks Heaps for that what EBC would you guys recommend?
ok fair enough, i though u were meaning rev limiter or something, i couldnt think what r&r was lol that why i said rest and relaxation lol
but u can still do it, ecu can handle it
well i have an apexi avcr controller, they are pretty good, lots of guy use them on skylines. or just go a blitz one or greddy profec b style or somehting similar its up to u how much u wanna spend really
Edited by 85URK
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
