u 2 would look mad hot in the porka, josh with his aviators on and his long blonde locks blowing in the wind, and adam arm out the sun roof waving at all the passers by lol
I dont wear aviators :)
I have big "Naughty Corey" style glasses, but white :P
That all depends on how many times you saw me go past..
The time I saw you, I was heading to Mdore
yeah that was the only time i saw u, some fag made me drag all his 52 ceiling battens up to top level of that shops, said they were needing them coz they were gonna be on site but when i got there they were no where to be seen. so i wa slike f**k it il do it myself.
Yeh - Peregain, town of the lazy.
Everyone turns up when they feel like it :P
hey josh, u seen that HZ kingswood up north area, has full purple paint job and white interior and chromies, and has plates "51KHZ" what a pimp mobile.
Yeh thats Matt's. He had the blue soarer with the big single turbo and drift king stickers.
It's ok, has a VN 5.0lt in it or something.
Hey guy just a quick question from your experiance what do you think i should do?
i have just bought a FMIC fixed up the exhaust and need to know what to do now?
i want to take the boost up to around 10 to 11 psi and so i will have to upgrade the ECU or buy a piggy back
i want to get up around the 200rwkw mark eventually.
What do you think?
u take that thing past 10psi on stock ecu....be prepared to hit R&R.
a simple apexi safc will get u to 200kw.
argh ok i remember that soarer used to see it round coolum heaps, that kinga looks ok, but one thing i would do is put some spoker rims on it daytons would finish it off better then those rims they just dont suit it.
Rest and relaxation? lol seriously why wouldnt stocko computer handle around 10-12psi? with supporting mods like fmic and boost controller?
rich and retard. mods + stock ecu= rich.
u push past 10psi, the ecu retards timing and dumps fuel= 1 huge flat spot in rev range
http://www.skylinesaustralia.com/forums/R3...;hl=rich+retard
Edited by r33cruiser
if u install your fmic, and get a boost controller your standard ecu should be able to handle 10 -12psi no problems, probably up to like 14-15psi im sure. with out any other mods. ecu is only better when u are going larger turbo then u need bigger injectors, and fuel pump etc then ecu to manage all that stuff. unless u are going to do that in the near future i wouldnt waste your money on a ecu at this stage.
Thanks Heaps for that what EBC would you guys recommend?
ok fair enough, i though u were meaning rev limiter or something, i couldnt think what r&r was lol that why i said rest and relaxation lol
but u can still do it, ecu can handle it
well i have an apexi avcr controller, they are pretty good, lots of guy use them on skylines. or just go a blitz one or greddy profec b style or somehting similar its up to u how much u wanna spend really
Edited by 85URK
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
